I'm working on my Arduino project and I'm stuck on how to parse received string from Ethernet Server respectively connected client.
Syntax of received string: "CD01,CM01,CT01,CS03,BR255" where comma is a delimiter.
I need to parse this string into chunks without letter(int cd = 1; int cm = 1, int ct = 1; int cs = 1; int br = 255;) store them like int variables into array and then use each one variable to execute specific operation like analogWrite(cs, br);. Does anybody know how to parse string this way?
All I've done until now is when I receive string separated into "" then set LED on currnet val.
Below is some simple code that does stuff with the contents of a comma delineated data string. You should be able to do something similar with the data string received from the server.
//zoomkat 3-5-12 simple delimited ',' string
//from serial port input (via serial monitor)
//and print result out serial port
String readString, substring;
//String servo1;
int loc;
Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
//expect a string like AA BB01/10/2014 CC12:23:25 DD32.2 EE5432 FF54.35,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
//if (c == '\n') { //looks for end of data packet marker
if (c == ',') {
Serial.println(readString); //prints string to serial port out
//do stuff
loc = readString.indexOf("BB");
//Serial.println(loc);
substring = readString.substring(loc+2, loc+12);
Serial.print("date is: ");
Serial.println(substring);
loc = readString.indexOf("CC");
substring = readString.substring(loc+2, loc+11);
Serial.print("time is: ");
loc = readString.indexOf("DD");
substring = readString.substring(loc+2, loc+6);
Serial.print("DD is: ");
loc = readString.indexOf("EE");
loc = readString.indexOf("FF");
substring = readString.substring(loc+2);
Serial.print("FF is: ");
readString=""; //clears variable for new input
substring="";
else {
readString += c; //makes the string readString
I hardly think that is going to fit in the 10 element array you have defined.
If you make inData large enough, the strtok function will then parse the string, returning tokens like "CD01", "CM01", etc.
Making sense of them is going to be challenging. If the string being received looked more like "CD=01,CM=01,..." then you could get tokens like "CD", "01", "CM", etc. and deal with names and values easily.
First at all I'd like to thank you both for advices and an example. I really appreciate it!!!
I've left an idea of Ehernet Server and I'm testing my parse function using Serial Monitor. I'm trying to parse and store each int value into array of integers. Strtok function was really helpful! But again I have few troubles.
#include <String.h>
String stringBuffer;
void setup(){
void loop(){
if(Serial.available()){
int isTrue= 1;
while(isTrue == 1){
if(c == 21)
isTrue = 0;
if (stringBuffer.length() < 100) {
stringBuffer += c;
Serial.print("Stored string: ");
Serial.println(stringBuffer);
int *data = parsed(stringBuffer);
int i = 0;
for(i = 0; i<5; i++){
Serial.println(data[i]);
int *parsed(String stringBuffered){
int inParse[5];
char pars[40];
stringBuffer.toCharArray(pars, 20);
char *pch;
int count = 0;
pch = strtok(pars, "CD CM CT CS BR :");
while(pch != NULL){
inParse[count] = atoi(pch);
count++;
Serial.print("Parsed value: ");
Serial.println(pch);
pch = strtok(NULL, "CD CM CT CS BR :");
return inParse;
When I start Serial Monitor uncontrollably heap of values are written down in loop. At which point I'm wrong?
Some simple code that might do what you need. Each data packet needs to have a comma , delimiter at the end of the packet.
String readString, data;
//String servo1;
int CD, CM, CT, CS, BR;
//expect a string like CD01,CM01,CT01,CS03,BR255,
if (c == ',') {
if(readString.indexOf("CD") >=0) {
data=readString.substring(2);
Serial.print("CD is: ");
Serial.println(data);
CD = data.toInt();
Serial.println(CD);
if(readString.indexOf("CM") >=0) {
readString=readString.substring(2);
Serial.print("CM is: ");
CM = readString.toInt();
Serial.println(CM);
if(readString.indexOf("CT") >=0) {
Serial.print("CT is: ");
CT = readString.toInt();
Serial.println(CT);
if(readString.indexOf("CS") >=0) {
Serial.print("CS is: ");
CS = readString.toInt();
Serial.println(CS);
if(readString.indexOf("BR") >=0) {
Serial.print("BR is: ");
BR = readString.toInt();
Serial.println(BR);
//do some stuff
data="";
else {
The while loop is entered when there is at least one character available to read. This code then loops, reading mostly nothing from the serial port until the String instance is full of crap.
Just about every point, starting with the String instance.
