Parse the response of a JSON REST Webservice
I intend to use a ESP8266 to connect to the internet to get the current time.
GET http://json-time.appspot.com/time.json?tz=Europe/Berlin returns
  "tz": "Europe\/Berlin",
  "hour": 12,
  "datetime": "Mon, 11 May 2015 12:18:11 +0200",
  "second": 11,
  "error": false,
  "minute": 18
Which Library would you advise to use to get the fields hour, minute and second into variables in my sketch?
I managed to communicate with my ESP8266 using AT commands. Also calling the web service worked. But how to automatically do this? Do I have to manually parse the result string (strip the HTTP headers ("Host", "Content-Type", "Content-Length", ...) and parse the JSON)? Or is there a library for that?
The stdlib has everything you need, IF you collect that data correctly - as a string.
PaulS:
You mean I have to work with strstr, strtok & friends? :wink:
I'd hoped for some more elaborate JSON libraries.
If you don't want to write it yourself (says a lot about people when they avoid learning/doing things on their own, just saying...) then you need to learn how to look under the right rocks. A quick look at the web location where Arduino code developers keep their libraries ( GITHUB) shows more than one JSON library attempt. I make no recommendation about how good any of the results are, but I have provided a link to the most popular JSON library for Arduino so far.
This is also a topic that has been discussed in this forum... you would have found conversations about it
...and for the record, the advice from PaulS was spot on.
pwillard:
I have written lots of C code in the old days, so no desire to write it myself (why re-invent the wheel?) :wink:
It's a chore - and I had hoped there's already a library for that.
GitHub - bblanchon/ArduinoJson: 📟 JSON library for Arduino and embedded C++. Simple and efficient.
Thanks for the link. After looking into it: It looks quite heavy-weight. Maybe it's really best to do the parsing myself ...
The problem with a general JSON parser is that there is just no way to do it without malloc()ing some memory.
Actually - I tell a lie. It could be done with a stream reader approach. You give the library some callbacks that get invoked at start object/end object and get given the parse stack. A good old LRLA(1) parser.
Hmm.
PaulMurrayCbr:
Someone said Yacc? ;D
