Parse value from USB serial input
Hello! I’ve been trying to program my Arduino UNO to receive the command ‘write x y HEXCOLOR’ over USB serial. So far I have this:
void writePixel(int x,int y, uint16_t color) {
  Tft.setPixel(x,y,color);
 String getValue(String data, char separator, int index)
  int found = 0;
  int strIndex[] = {0, -1};
  int maxIndex = data.length()-1;
  for(int i=0; i<=maxIndex && found<=index; i++){
    if(data.charAt(i)==separator || i==maxIndex){
        found++;
        strIndex[0] = strIndex[1]+1;
        strIndex[1] = (i == maxIndex) ? i+1 : i;
  return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
//Correct format for pixel set it this:
//write x y hex
//Example
//write 100 200 0xFF3366
  // send data only when you receive data:
        String content = "";
  char character;
  while(Serial.available()) {
      character = Serial.read();
      content.concat(character);
      delay(10);
  if (content != "") {
    Serial.println(content);
    if(content.indexOf("write") >=0) {
      Serial.println("GOT WRITE");
The problem is that
getValue(content,' ', 1)
(Returns the X value)
Returns a string instead of an int. I also need to convert a string (“0xFF3366”) to uint16_t.
So my questions is this: How do I convert a String to an int and convert a String to an uint16_t?
Take a look on the Serial - command and/or SoftwaSerial :slight_smile:
The Serial - command reads and writes datas over the USB-cable you have connected the UNO to the pc.
Hello,
Take a look at strtol!
I have extracted the values with strtoi/strtol and the command check with String.startsWith.
I hope I could have helped you.
Neither worked. My incoming data is formatted like this:
String stringMessage = "MESSAGE"
And what value do you expect to get when you convert "MESSAGE" to an unsigned long? What value do you actually get?
