Hi all.
the ESP32_ILI9341 touch menu sketch got compiling error, how to fix please?
Thanks
Adam
#include <WiFi.h> // Wifi
#include <WiFiUdp.h> // UDP
#include <NTPClient.h> // time server
#include <SD.h> // SD Card
//#include <TinyGsmClient.h> // cell stuff.
#include <SPI.h> // spi
#include <Adafruit_GFX.h> // graphics
#include <Adafruit_ILI9341.h> // display
#include <Adafruit_MLX90614.h> // Melexis IR temp
#include <Adafruit_MLX90640.h> // Flir
#include <MAX30105.h> // MAX30102 oxi/pulse (on hold just yet)new compile to ESP32 WROOM 32 today (9-15-2020)
#include <heartRate.h> // Heart rate calculating algorithm
#include <XPT2046_Touchscreen.h> // touch
#include <SparkFunBME280.h> // Click here to get the library: http://librarymanager/All#SparkFun_BME280
#include <SparkFunCCS811.h> // Air Quality Index
#include <ClosedCube_HDC1080.h> // temp & humidity
#include <Adafruit_SI1145.h> // GY-1145 light quality sensor
#include <RTClib.h> // RTC library
#include <time.h> // standard time stuff
#include <Adafruit_MPU6050.h> // Gyro
#include <Adafruit_TCS34725.h> // RGB Sensor
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include "Helper.h" // my helper header
// SETUP ***************************************************************
Serial.begin(115200);// for debug purposes.
// Keep power when running from battery
//bool isOk = setPowerBoostKeepOn(1);
InitDisplay();
showBiosInfo();
scanI2CBus();
initializeSensorGroup();
delay(2000);
ClearScreen();
infoBlocks();
MENU_MODE = 0;
showMenuSystem(MENU_MODE);
delay(200);
initMyTouch();
delay(200);
clearStatus();
//BUILTIN LED
pinMode (2, OUTPUT);
digitalWrite(2, LOW);
//touch irq pin
pinMode (35, INPUT);
AttachTouch();
// LOOP *******************************************************************
//set the BUILTIN_LED off.
digitalWrite(BUILTIN_LED, LOW);
// if TouchType is 0 then here is where the actual parsing of the button occurs - action();
// first we check for keypress by looking at PAD_DOWN event
//action(); will invoke the loop
if (PAD_DOWN && GLOBAL_TOUCH_TYPE == MENU) {
// at this point to remember is that the interrupt routine
//just returns the vales to TouchX & TouchY and sets PAD_DOWN = true
// here we can take the time to analyze x,y and come up with BUTTON_NUMBER
BUTTON_NUMBER = parseMenuTouch(TouchX , TouchY );
action(BUTTON_NUMBER);
PAD_DOWN = false;
if (PAD_DOWN && GLOBAL_TOUCH_TYPE == NUMERIC) {
// has a valid entry(number,.,<OK>) been entered?
GLOBAL_NUMBER = parseForNumber(TouchX, TouchY);
PAD_DOWN = false;
// next skip through the loop...anything else you need to loop
//delay(250);//debounce for now...
// all of the items you need to run can be done like this...
// just activate your items one at a time set SystemMode to 1-4.
if (SystemMode == 0) {
//display what you need to in your idle loop
if (SystemMode == TIME) {
showDateTime();
if (SystemMode == GYRO) {
showGyroData();
if (SystemMode == OXIMETER) {
//display what you need to in your oxi loop
if (SystemMode == FLIR) {
//display what you need to in your FLIR loop
updateFlirImage();
if (SystemMode == ENVIRONMENT) {
//display what you need to in your BME280 loop
showWeather();
if (SystemMode == RGB_SCAN) {
showRGBReader();
// and so on...
}// end of loop
ERROR:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 40MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Enabled"
C:\Users\Xinzhou\Desktop\LS1\3 EYE_clock_game_Stream_health_GPS_sth\00_sth\ESP32_XPT2046_ILI9341_Tmenu_M\ESP32_XPT2046_ILI9341_Tmenu_M.ino: In function 'void loop()':
ESP32_XPT2046_ILI9341_Tmenu_M:133:21: error: 'parseMenuTouch' was not declared in this scope
ESP32_XPT2046_ILI9341_Tmenu_M:134:5: error: 'action' was not declared in this scope
C:\Users\Xinzhou\Desktop\LS1\3 EYE_clock_game_Stream_health_GPS_sth\00_sth\ESP32_XPT2046_ILI9341_Tmenu_M\ESP32_XPT2046_ILI9341_Tmenu_M.ino:134:5: note: suggested alternative: 'sigaction'
sigaction
ESP32_XPT2046_ILI9341_Tmenu_M:166:5: error: 'showWeather' was not declared in this scope
showWeather();
C:\Users\Xinzhou\Desktop\LS1\3 EYE_clock_game_Stream_health_GPS_sth\00_sth\ESP32_XPT2046_ILI9341_Tmenu_M\ESP32_XPT2046_ILI9341_Tmenu_M.ino:166:5: note: suggested alternative: 'showStatus'
showWeather();
showStatus
ESP32_XPT2046_ILI9341_Tmenu_M:170:5: error: 'showRGBReader' was not declared in this scope
showRGBReader();
exit status 1
option enabled in File -> Preferences.
sigaction
showWeather();
showWeather();
showStatus
showRGBReader();
exit status 1
Read through this section.
Maybe change the functions to the ones suggested?
Thank you v205.
I changed what there is suggestion, made some progress, still error: 'parseMenuTouch' was not declared in this scope
C:\Users\Xinzhou\Desktop\LS1\3 EYE_clock_game_Stream_health_GPS_sth\00_sth\ESP32_XPT2046_ILI9341_Tmenu_A\ESP32_XPT2046_ILI9341_Tmenu_A.ino: In function 'void loop()':
ESP32_XPT2046_ILI9341_Tmenu_A:132:21: error: 'parseMenuTouch' was not declared in this scope
ESP32_XPT2046_ILI9341_Tmenu_A:135:27: error: too few arguments to function 'int sigaction(int, const sigaction*, sigaction*)'
sigaction(BUTTON_NUMBER); /// Suggestiob
In file included from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\sys-include\signal.h:6,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\sys-include\time.h:178,
from C:\Users\Xinzhou\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/newlib/platform_include/time.h:22,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\sys-include\sys\time.h:414,
from C:\Users\Xinzhou\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/newlib/platform_include/sys/time.h:16,
from C:\Users\Xinzhou\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5/tools/sdk/esp32/include/newlib/platform_include/pthread.h:18,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr-default.h:48,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr.h:151,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\ext\atomicity.h:35,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\bits\basic_string.h:39,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\string:52,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\stdexcept:39,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\array:39,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\tuple:39,
from c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\functional:54,
from C:\Users\Xinzhou\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\cores\esp32/HardwareSerial.h:49,
from C:\Users\Xinzhou\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\cores\esp32/Arduino.h:174,
from sketch\ESP32_XPT2046_ILI9341_Tmenu_A.ino.cpp:1:
c:\users\xinzhou\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\sys-include\sys\signal.h:183:5: note: declared here
int sigaction (int, const struct sigaction *, struct sigaction *);
ESP32_XPT2046_ILI9341_Tmenu_A:168:15: error: too few arguments to function 'void showStatus(String)'
showStatus();
In file included from C:\Users\Xinzhou\Desktop\LS1\3 EYE_clock_game_Stream_health_GPS_sth\00_sth\ESP32_XPT2046_ILI9341_Tmenu_A\ESP32_XPT2046_ILI9341_Tmenu_A.ino:94:
C:\Users\Xinzhou\Desktop\LS1\3 EYE_clock_game_Stream_health_GPS_sth\00_sth\ESP32_XPT2046_ILI9341_Tmenu_A\Helper.h:336:6: note: declared here
void showStatus(String z) {
ESP32_XPT2046_ILI9341_Tmenu_A:172:5: error: 'showRGBReader' was not declared in this scope
showRGBReader();
exit status 1
Thanks.
yes.
and when commented out: // BUTTON_NUMBER = parseMenuTouch(TouchX , TouchY );
got another error at the next line: 'action' was not declared in this scope
I've tried with 'sigaction' and got error of: too few arguments to function 'int sigaction(int, const sigaction*, sigaction*)'
and still not yet solve 'parseMenuTouch' problem.
ERROR:
Arduino: 1.8.19 (Windows 7), Board: "ESP32 Dev Module, FTDI Adapter, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
E:\ENGINEERING\DIY\Electronic\ESP32\ESP32 GPS LCD map\XPT2046_Touchscreen-master\ESP32TouchMenu_M1\ESP32TouchMenu_M1.ino: In function 'void loop()':
ESP32TouchMenu_M1:137:28: error: too few arguments to function 'int sigaction(int, const sigaction*, sigaction*)'
In file included from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\sys-include\signal.h:6,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\sys-include\time.h:178,
from C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/newlib/platform_include/time.h:22,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\sys-include\sys\time.h:414,
from C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/newlib/platform_include/sys/time.h:16,
from C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/include/newlib/platform_include/pthread.h:18,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr-default.h:48,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr.h:151,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\ext\atomicity.h:35,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\bits\basic_string.h:39,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\string:52,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\stdexcept:39,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\array:39,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\tuple:39,
from c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\include\c++\8.4.0\functional:54,
from C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/HardwareSerial.h:49,
from C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6\cores\esp32/Arduino.h:174,
from sketch\ESP32TouchMenu_M1.ino.cpp:1:
c:\users\hua.dellv-pc\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch5\xtensa-esp32-elf\sys-include\sys\signal.h:183:5: note: declared here
exit status 1
