parsing a string and assigning each character to a variable
remove
I'm stumped. I don't see your error.
You could:
  • print sx1272.packet_received.data
  • put different values in it.
  • swap vbat and vcap to see if it changes anything.
Thanks :(, its mind boggling.
Is it blank? or is your transmitter sending a space or a no-break-space ascii value? Print out the ascii value instead, and check what it sends.
Weird bugs like that are usually stemming from a false assumption.
When the error is not where you are looking then look elsewhere: TammyTam is right. It's one possible issue.
You have not posted a complete program. In that case the problem is usually in the piece(s) you have omitted.
Print the full string as received before you try to print the individual elements - that way you can see if there is an item different from what you expect. This seems the most likely cause of the problem.
I would be surprised if the variable name "vcap" has any special significance for the compiler - but it would be worth trying another name - perhaps "vcapxx"
...R
Buffer overflow here:
char id[3];
char distance[3];
id[0] = sx1272.packet_received.data[0];
id[1] = sx1272.packet_received.data[1];
id[3] = '\0';
distance[0] = sx1272.packet_received.data[6];
distance[1] = sx1272.packet_received.data[7];
distance[3] = '\0';
Hi Guix, I'm sorry, I don't understand, what am I doing wrong?
Thanks
Should be:
distance[2] = '\0';
Cant believe I missed that
Me too, I'm blind. Funny when you look at something for ages you can't see the obvious.
Thanks for all the help.
The code you posted does not compile for me, so maybe you should start over.
distance[3] = '\0';
I did not notice that!! Good catch!!!
Now that imples the compiler allocated vcap after distance.
