Parsing GET to get word submitted through a form
So I've set up a web server with my arduino uno and I am having trouble getting the word from the headers. I guess I'm little confused on how to get it. I've tried looking up some methods but none seem to prevail. Maybe i'm not doing the methods properly I just wonder if someone could point me into the right direction.
Here is my code
#include <SPI.h>
#include <Ethernet.h>
#include <LiquidCrystal.h>
#include <Time.h>
#include "RTClib.h"
#if defined(ARDUINO_ARCH_SAMD)
// for Zero, output on USB Serial console, remove line below if using programming port to program the Zero!
   #define Serial SerialUSB
#endif
RTC_Millis rtc;
LiquidCrystal lcd(9, 8, 7, 6, 5, 2);
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x98, 0xAD };
// IPAddress ip(192, 168, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  Serial.begin(57600);
  rtc.begin(DateTime(F(__DATE__), F(__TIME__)));
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  lcd.begin(16, 2);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  DateTime now = rtc.now();
  lcd.setCursor(0,0);
  lcd.print(" ");
  lcd.print(now.hour(), DEC);
  lcd.print(':');
  lcd.print(now.minute(), DEC);
  lcd.print(':');
  lcd.print(now.second(), DEC);
  lcd.print("  ");
  lcd.print(now.month(), DEC);
  lcd.print('/');
  lcd.print(now.day(), DEC);
  if(client){
    Serial.println("New Client");
    boolean clib = true;
    while(client.connected()){
      if(client.available()){
        char c = client.read();
        Serial.print(c);
        if(c == '\n' && clib){
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println("Refresh: 5");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          client.println("<head><title> Testing </title></head><body><h1>Testing http requesting using GET method</h1>");
          client.println("<form action='GET'><input type='textbox' name='timezone'><button type='submit'>submit</button></form></body></html>");
        if(c == '\n'){
          clib = true;
        else if(c != '\r'){
          clib = false;
    delay(1);
    client.stop();
    Serial.println("Client disconnected");
here are is the data I get back:
server is at 192.168.0.14
New Client
GET /GET?timezone=Words HTTP/1.1
Host: 192.168.0.14
Connection: keep-alive
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,/;q=0.8
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/48.0.2564.97 Safari/537.36
Referer: http://192.168.0.14/
Accept-Encoding: gzip, deflate, sdch
Accept-Language: en-US,en;q=0.8
Im trying to get what comes after the /GET?timezone=
The data from the GET request is not stored anywhere. You can only parse data that you have stored.
There are PLENTY of examples of storing and parsing GET requests. Do some hunting.
Have looked up many articles about parsing the data and still have no idea how to get the data I want back.
Simple server code that generates a simple web page, captures what is sent from the web page to the server, then performs an action based on what is in the GET request.
//zoomkat 10-6-13
//simple button GET with iframe code
//open serial monitor to see what the arduino receives
//use the ' instead of " in html ilnes
//address will look like http://192.168.1.102:84/ when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //ethernet shield mac address
byte ip[] = { 192, 168, 1, 102 }; // arduino IP in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(4, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("servertest1"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
          //now output HTML data header
             if(readString.indexOf('?') >=0) { //don't send new page
               client.println("HTTP/1.1 204 Zoomkat\r\n\r\n");
             else {
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          client.println("<a href='/?on1' target='inlineframe'>ON</a>");
          client.println("<a href='/?off' target='inlineframe'>OFF</a>");
          client.println("<IFRAME name=inlineframe style='display:none'>");
          client.println("</IFRAME>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on1") >0)//checks for on
            digitalWrite(4, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(4, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
Finally figured it out thank you so much!!! :grinning:
