I'm trying to do the following:
Using a Digispark as the controller, pull data from a GPS (EM-406A - https://www.sparkfun.com/datasheets/GPS/EM-406A_User_Manual.PDF) via the SoftwareSerial and outputting to a Serial LCD (https://www.sparkfun.com/products/9395). Digispark doesn't have hardware serial. According to this post (https://digistump.com/board/index.php?topic=927.0) there is some software serial written into TinyCore that the Digispark uses, so I'm using that for output to the LCD.
The Digispark doesn't have enough memory to use TinyGPS - nor do I really need that. The only GPS data I'm interested in is the altitude. (I'm trying to build a small, lightweight altimeter to put on a cheap quadcopter - WLtoys v222 - I happened to already have all these parts already).
I think I'm close - the logic seems to be fine and the hardware seems to work as expected. The LCD works fine and the GPS seems to be acquiring a position (based on it's blinking LED). But, I suspect there's something wrong in the code and I'm not very strong in that area. I modified the code from here: http://www.cooking-hacks.com/documentation/tutorials/arduino-gps#nmea_arduino
Can someone help me out and take a look at the code to see what might be happening? Or sugget an alternative way to get the Altitude data? You'll see that I added some "DEBUG" prints in the code. The farthest it seems to get is to print "Waiting GPS data..." and then "DEBUG1". Nothing gets printed after that. The code is below.
I appreciate any help! Thanks!
// From http://www.cooking-hacks.com/documentation/tutorials/arduino-gps#nmea_arduino
#include <SoftwareSerial.h>
#define txPin 5 //tx pin in GPS connection
#define rxPin 3 //rx pin in GPS connection
// Set up the GPS serial port
SoftwareSerial gps = SoftwareSerial(rxPin, txPin);
byte byteGPS = 0;
int i = 0;
int state = 0;
char dataGPG[100]="";
char *pch;
char *GGA[15];
int sat = 0;
//setup for Serial Port
//setup for GPS Serial Port
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
gps.begin(4800);
//setup satellites signal
pinMode(1, OUTPUT);
digitalWrite(1, LOW); // Turn off the led until a satellite signal
Serial.write(254); // clear display
Serial.write(1);
Serial.write(254); // cursor to beginning of first line
Serial.write(128);
Serial.print("Sleeping for 60 seconds");
delay(60000);
Serial.write(1);
Serial.write(128);
Serial.print("Waiting GPS data...");
// Prepare all for reading GPS Serial Port
memset(dataGPG, 0, sizeof(dataGPG)); // Remove previous readings
byteGPS = 0; // Remove data
byteGPS = gps.read(); // Read the byte that is in the GPS serial port
Serial.print("DEBUG1");
// Find the desired string
while(byteGPS != '
Serial.print("DEBUG2");
// Save the string in an array
i=1;
dataGPG[0] = '
Serial.print("DEBUG3");
while(byteGPS != '*' )
dataGPG[i]=byteGPS;
i++;
dataGPG[i]= '\0';
string(); // Call to the function that manipulates our string
Serial.print("DEBUG4");
This function will allow us to identify the data we need to get the longitude, latitude ...
void string()
i=0;
memset(GGA, 0, sizeof(GGA)); // Remove previous readings
pch = strtok (dataGPG,",");
// Analyze the saved interval in pch to see if it the needed string
if (strcmp(pch,"$GPGGA")==0)
while (pch != NULL)
pch = strtok (NULL, ",");
GGA[i]=pch;
i++;
plot(GGA,"$GPGGA"); // Call to the function that is going to display the data
This function organize the gps data received for printing in the serial monitor.
void plot(char **GGAPrint, char *trama)
state = atoi(GGAPrint[5]);
sat = atoi(GGAPrint[6]);
if(trama=="$GPGGA" && state==1)
digitalWrite(1, HIGH); // Then there are satellites, the LED switch ON
//Serial.println("");
//Serial.println("----------------------------------------------");
//Serial.print("UTC Hour -> ");
//Serial.println(GGAPrint[0]);
//Serial.print("Latitude -> ");
//Serial.print(GGAPrint[1]);
//Serial.println(GGAPrint[2]);
//Serial.print("Longitude -> ");
//Serial.print(GGAPrint[3]);
//Serial.println(GGAPrint[4]);
//Serial.print("GPS quality: 0=null; 1=GPS fixed -> ");
//Serial.println(GGAPrint[5]);
//Serial.print("Number of satellites -> ");
//Serial.println(sat);
//Serial.print("Horizontal Dilution of Precision -> ");
//Serial.println(GGAPrint[7]);
Serial.print("Antenna altitude -> ");
Serial.print(GGAPrint[8]);
Serial.println(GGAPrint[9]);
//Serial.print("Geoid Separation -> ");
//Serial.print(GGAPrint[10]);
//Serial.println(GGAPrint[11]);
else // If no satellite connection
digitalWrite(1, LOW); // Turn off the LED
//Serial.println("-----------------------------");
//Serial.print("|--- Satellites Used -->");
//Serial.print(sat);
//Serial.println(" |");
Serial.println("Waiting location");
