mfusco
1
In this Processing documentation, a JSON file can be loaded with this line of code:
json = loadJSONObject("data.json");
I would like to do the same, but from a serial input from an Arduino. I tried this:
val = myPort.readString();
if (val != null) {
data = loadJSONObject(val);
However, I get the error:
The file is missing or inaccessible, make sure the URL is valid or that the file has been added to your sketch and is readable.
Is there a way to read and parse serial JSON data?
horace
2
possibly you have end of line characters in the String
try
val = myPort.readStringUntil('\n')
readStringUntil() will read the string until '\n' is found and discards it
mfusco
3
Thank you for your response, however that didn't work.
horace
4
with readString() try setting the Serial monitor input to "No Line Ending"
mfusco
5
Thanks. How would I go about that?
Personally I would ask the question on the Processing forum: https://discourse.processing.org/.
There are a few people here that have worked with Processing but not many.
system
Closed
7
