Parsing read SD file into 2 variables
Hello all,
Recently I started some tests controlling water heater with temperature sensor data testing a small dataset to control water temperature with variation each 3 hours. The current code is as follows:
#include <NTPClient.h>
#include <WiFi.h>
#include <WiFiUdp.h>
//WiFi Conf
const char *ssid     = "ssid_addr";
const char *password = "wifi_password";
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
unsigned long current_time;
// Sensors Conf (fixed value just to test relay response)
float temperature = 30.5;
//Relay Conf
const int relay = 26;
struct SetPoint {
  unsigned long time;
  float temperature;
#define DATA_SIZE  8
SetPoint scen1[DATA_SIZE] = {
  {1616952559, 32.4},
  {1616952739, 10.2},
  {1616952859, 10.4},
  {1616952867, 40.2},
  {1616952927, 20.4},
  {1616952928, 35.2},
  {1616952945, 22.4},
  {1616952947, 28.2}
unsigned int pos = 0;
  pinMode(relay, OUTPUT);
  WiFi.begin(ssid, password);
  while ( WiFi.status() != WL_CONNECTED ) {
    delay ( 500 );
    Serial.print ( "." );
  timeClient.begin();
  timeClient.update();
  long current_time =  timeClient.getEpochTime();
  if (pos < DATA_SIZE && current_time >= scen1[pos].time) {
    set_thermostat(/*data[pos].temperature, temperature*/);
    pos++;
  Serial.println(timeClient.getEpochTime());
  Serial.println(timeClient.getFormattedTime());
  Serial.println(pos);
  delay(3000);
void set_thermostat() {
  if (temperature < scen1[pos].temperature) {
    digitalWrite (relay, HIGH);
  else if (temperature > scen1[pos].temperature) {
    digitalWrite (relay, LOW);
Now I want to use a larger file with different datapoints and an option is to store them in a sdcard and, then, the microcontroller parses each line to control the temperature with an interval of three hours.
There will be about 720 lines with the following structure ("Scen" is the temperature simulation scenarios that will be the reference to turn the relays on or off):
    Time,UNIX,Scen1,Scen2,Scen3
    21/04/2021 00:00:00,1618963200,"27.45","29.01","30.85"
    21/04/2021 21:00:00,1619038800,"26.16","27.82","29.75"
    21/04/2021 06:00:00,1618984800,"25.28","26.83","29.02"
    21/04/2021 09:00:00,1618995600,"24.62","26.49","28.51"
    21/04/2021 12:00:00,1619006400,"27.19","29.47","29.53"
    21/04/2021 15:00:00,1619017200,"30.65","34.07","30.50"
    21/04/2021 18:00:00,1619028000,"31.87","35.78","31.78"
    21/04/2021 21:00:00,1619038800,"30.43","35.20","30.88"
    22/04/2021 00:00:00,1619049600,"28.45","31.86","29.47"
The problem is that it is hard for me to find out how to parse data from the file into two variables (UNIX Time and temperature), for each temperature scenario, as used here:
struct SetPoint {
  unsigned long time;
  float temperature;
#define DATA_SIZE  8
//scenario 1 array
  {1616952559, 32.4},
  {1616952739, 10.2},
  {1616952859, 10.4},
  {1616952867, 40.2},
  {1616952927, 20.4},
  {1616952928, 35.2},
  {1616952945, 22.4},
  {1616952947, 28.2}
Is there an effective way to get what I'm looking for?
Read the line of data in a char array then use strtok() to split off the sections that you want
Thanks, @UKHeliBob. Will work on it today and share the advances.
This topic was automatically closed after 120 days. New replies are no longer allowed.
