parsing Serial char array to 3 variables
So i'm trying to get serial data from a bluetooth device and then get 3 variables out from it. For the sake of debugging i'm trying to make it work with standard Serial over usb first. My input is in the following format "3,4,6" where 3 4 and 6 each represent separate variables that need to be stored as doubles and is separated by the "," as the delimiter. I put together the following code from looking at examples here and there on the forum.
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
char delimiters[] = ",";
char* valPosition;
double angle[] = {0, 0, 0};
  readserialtochars();
  parsedata();
void readserialtochars() {
   while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
void parsedata() {
 if(started && ended)
  valPosition = strtok(inData, delimiters);
   for(int i = 0; i < 3; i++){
    angle[i] = atof(valPosition);
    Serial.println(angle[i]);
    valPosition = strtok(NULL, delimiters);
    started = false;
    ended = false;
    index = 0;
The problem i'm getting is when i send a in the following in the serial comm "3,4,6" nothing is outputted where i should get my 3 values in individual lines.
This seems to be something that is required often, is there any sort of library or function inbuilt into the arduino library that handles this?
zer044:
What about sending the starting and ending packet markers?
so are you saying i send "<3,4,6,>" instead? or "\03,4,6,\0"
The sketch you have defines the start of packet marker as '<' and end of packet marker as '>', so yes, you should be sending "<3,4,6>" instead of "3,4,6"
Yes.
or "\03,4,6,\0"
No.
Brilliant works now!!!
