Parsing serial in data - a bit stuck!
I am trying to do something very simple with serial data coming into the Arduino. For whatever reason, I am now totally stuck with parsing the data coming in.
Here is what I want to do:
Serial coming in as decimal numbers, 134, 115, 100 etc…
I want the Arduino to look at these numbers, and do something depending on if they are greater or less than a set variable.
Here is my code so far…
#include <Servo.h>
Servo myservo1; // create servo object to control a servo
Servo myservo2; // create servo object to control a servo
myservo1.detach();
myservo2.detach();
if (Serial.available() > 0) {
int moveServo = Serial.read();
if (moveServo > 140)
myservo1.attach(9);
myservo1.write(110);
myservo2.attach(10);
myservo2.write(110);
else if (moveServo < 120)
myservo1.attach(9);
myservo1.write(50);
myservo2.write(50);
myservo1.detach();
myservo2.detach();
Serial.println(moveServo);
Any help?
Thanks.
That code looks OK -- what's the trouble with it?
It does not work, if I send 110 the servos should turn one way, and eg 160, the other way?
Anything I send just starts them turning, the detach does not work either :frowning:
Serial.read() only returns the first byte available (in ascii). So, you will have to do some more work to receive a 3 digit number. There are many examples on the forum. I don't have time at the moment, but if you can't find something I will try to find a link tomorrow.
Yup thats the exact problem I have, all I am getting is:
1 0 0
I'll have a look in the meantime for an example, but if you do find a specific one, that will be great!
Cheers.
To get that code working you need to know how the sending data is formatted. If its always 3 ascii characters (with no trailing carriage return) you can do something like this:
  if (Serial.available() >=3) {
    int moveServo = 0;
    for(int mult = 100; mult; mult /= 10){
      int digit = Serial.read() - '0' ;  // convert ascii to an integer
      moveServo += digit * mult;
    if (moveServo > 140)     {
      // write value to servo
You would need to modify the code to ignore a terminating carriage return if your incoming string has this.
Also, why are you detaching after each write? Perhaps you can say more about what you want your sketch to do.
I have a netbook on wheels...
The netbook uses it's camera to follow targets, feeds the coords over serial to a couple of Futaba s3003 modded servos, via the Arduino.
I don't need to detach the servos, it was just for testing.
I'll check your code out, thanks :-)
Cool - looking forward to reading about how you get on :)
Have fun!
This thread should help you get going:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1232462410/7
