Hi i am sending the following over serial from pi to arduino: (not exact numbers but same layout and characters)
a123:b233:c142:d142:e124:f124:g123:h123:i124:j127:k128:l125:m127:n125:o124:p126:q136:r125:s152:t124:u124:v123:w123:x124:
how ever i only receieve part of this, this is shown in the arduino serial window:
Data entered: a212:b126:c000:d255:e129:f212:g126:h000:i255:j129:k212:l126:m23
as you can see it only reads up to the first 2 characters after m and i haven't a clue why? i have increased my buffer size and increased the delay but still nothing. I understand its not the most efficient way to parse a string but it would appear the problem is on the receiving side of things. Can anyone help? Thanks
char buffer[400];
int c1,c2,c3,c4,c6,c7,c8,c9,c10,c11,c12,c13,c14,c15,c16,c17,c18,c19,c20,c21,c22,c23,c24;
int RedPin = 11;
int GreenPin = 10;
int BluePin = 9;
while(Serial.available())
Serial.read();
if (Serial.available() > 0) {
int index=0;
delay(300); // let the buffer fill up
int numChar = Serial.available();
if (numChar>180) {
numChar=180;
while (numChar--) {
buffer[index++] = Serial.read();
splitString(buffer);
void splitString(char* data) {
Serial.print("Data entered: ");
Serial.println(data);
char* parameter;
parameter = strtok (data, ":"); // Note that this is a space before the comma in " , "
while (parameter != NULL) {
setLED(parameter);
parameter = strtok (NULL, ":"); // space before the comma in " , "
// Clear the text and serial buffers
for (int x=0; x<180; x++) {
buffer[x]='\0';
Serial.read();}
void setLED(char* data) {
if ((data[0] == 'a') || (data[0] == 'A')) {
int Ans = strtol(data+1, NULL, 10);
Ans = constrain(Ans,0,255);
analogWrite(GreenPin, Ans);
Serial.print("C1 = ");
Serial.println(Ans);
if ((data[0] == 'b') || (data[0] == 'B')) {
Serial.print("C2 = ");
if ((data[0] == 'c') || (data[0] == 'C')) {
analogWrite(BluePin, Ans);
Serial.print("C3 = ");
if ((data[0] == 'd') || (data[0] == 'D')) {
Serial.print("C4 = ");
if ((data[0] == 'e') || (data[0] == 'E')) {
Serial.print("C5 = ");
if ((data[0] == 'f') || (data[0] == 'F')) {
Serial.print("C6 = ");
} if ((data[0] == 'g') || (data[0] == 'G')) {
Serial.print("C7 = ");
if ((data[0] == 'h') || (data[0] == 'H')) {
Serial.print("C8 = ");
if ((data[0] == 'i') || (data[0] == 'I')) {
Serial.print("C9 = ");
if ((data[0] == 'j') || (data[0] == 'J')) {
Serial.print("C10 = ");
if ((data[0] == 'k') || (data[0] == 'K')) {
Serial.print("C11 = ");
if ((data[0] == 'l') || (data[0] == 'L')) {
Serial.print("C12 = ");
} if ((data[0] == 'm') || (data[0] == 'M')) {
Serial.print("C13 = ");
if ((data[0] == 'n') || (data[0] == 'N')) {
Serial.print("C14 = ");
if ((data[0] == 'o') || (data[0] == 'O')) {
Serial.print("C15 = ");
} if ((data[0] == 'p') || (data[0] == 'P')) {
Serial.print("C16 = ");
if ((data[0] == 'q') || (data[0] == 'Q')) {
Serial.print("C17 = ");
if ((data[0] == 'r') || (data[0] == 'R')) {
Serial.print("C18 = ");
} if ((data[0] == 's') || (data[0] == 'S')) {
Serial.print("C19 = ");
if ((data[0] == 't') || (data[0] == 'T')) {
Serial.print("C20 = ");
if ((data[0] == 'u') || (data[0] == 'U')) {
Serial.print("C21 = ");
} if ((data[0] == 'v') || (data[0] == 'V')) {
Serial.print("C22 = ");
if ((data[0] == 'w') || (data[0] == 'W')) {
Serial.print("C23 = ");
if ((data[0] == 'x') || (data[0] == 'X')) {
Serial.print("C24 = ");
