Hello,
I have some values in TXT file on SD card.
All I'm trying to do is to get first 10 values from file and store them into array.
I have managed to read whole file (74 values example) and build array correctly, but if try to count up to 10 lines only with this code:
if (arrayC++ > 10){break;}
it somehow does only even steps and fills array at even positions.
Any ideas?
Code:
#include <SPI.h>
#include <SD.h>
File myFile;
int some_array[10];
int arrayC = 0;
readSD();
void loop () {}
void readSD() {
if (!SD.begin(53)) {
Serial.print("NO SD CARD!");
return;
Serial.println("SD CARD FOUND");
myFile = SD.open("2.txt");
if (myFile) {
Serial.println("FILE FOUND");
while (myFile.available()) {
switch ((char)myFile.peek()) {
case ',':
myFile.read();
case '\r':
myFile.read();
default:
int newV = myFile.parseInt();
some_array[arrayC] = newV;
arrayC++;
//if (arrayC++ > 10){arrayC = 10; break;}
Serial.println(arrayC);
myFile.close();
Serial.println("PARSE DONE");
for (int i = 0; i < 10; i++){
Serial.print("I="); Serial.print(i); Serial.print(" = ");
Serial.println(some_array[i]);
Serial.println("ALL DONE!");
2.txt File:
125,
685,
247,
687,
957,
325,
698,
384,
397,
568,
897,
125,
685,
124,
687,
957,
325,
698,
568,
etc....
Serial output with IF line:
SD CARD FOUND
FILE FOUND
2
4
6
8
10
PARSE DONE
I=0 = 125
I=1 = 0
I=2 = 685
I=3 = 0
I=4 = 247
I=5 = 0
I=6 = 687
I=7 = 0
I=8 = 957
I=9 = 0
ALL DONE!
Serial output without IF line:
SD CARD FOUND.
FILE FOUND
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
PARSE DONE
I=0 = 125
I=1 = 685
I=2 = 247
I=3 = 687
I=4 = 957
I=5 = 325
I=6 = 698
I=7 = 384
I=8 = 397
I=9 = 568
ALL DONE!
