Part of code stops working when display is changed.
2000ms delay
Another no-no. There is rarely a need for delays, and using them usually causes other problems.
To learn how to program Arduinos without them, we recommend to study the Blink Without Delay example, explained here.
jremington:
Thank you for that, but I don't think that would solve my issue. I asked where to put the function call. I said that when I deleted it, it caused the delay to apply. I don't need help with the delay. When I write my own code, I will try to use blink without delay, but right now it is not causing any problems and I need help with where to put the function call. Where does it make sense to put it?
jremington:
Hi, original author of the code here. I was hoping if you could double check if what I’ve done makes sense after your feedback.
Basically, I removed the call to writeTargetTemperature() (serial I/O) from the updateEncoder() (interrupt).
Then I removed the delay(2000) from the main loop().
I’ve added a check with millis() to refresh the display periodically.
  // read temperature etc...
  // only refresh the display periodically to prevent flicker
  if (millis() - time_now > refresh_freq) {
    time_now = millis();
    updateDisplay();
The complete code is here https://github.com/tehmantra/proofing_box/blob/320c96b8d6f2a2b6c6ce441de979819f31925f35/proofing_box.ino
Thanks
tehmantra:
Hi, original author of the code here. I was hoping if you could double check if what I've done makes sense after your feedback.
The complete code is here proofing_box/proofing_box.ino at 320c96b8d6f2a2b6c6ce441de979819f31925f35 · tehmantra/proofing_box · GitHub
Thanks
And the help is over here so it would be better to post your code here. If it is too large, attach it.
blh64:
#include "DHT.h" // Adafruit DHT Sensor Library - tested with v1.3.10
#include "SoftwareSerial.h"
const boolean debug = false;
const int pin_enco_1 = 2; // 2/3 are special pins. the encoder must be here
const int pin_enco_2 = 3;
const int pin_enco_sw = 7; // encoder switch
const int pin_disp_tx = 4; // pin that the display RX is connected to.
const int pin_disp_rx = 11; // needed to create the software serial. doesn't need physical connection
const int baud_rate = 9600; // set correct baud rate. default of s7s is 9600
const int disp_brightness = 255;
const int pin_dht = 5; // pin that the DHT is connected to
const int dht_type = DHT22; // DHT 22 (AM2302)
const int refresh_freq = 100; // time to wait between loops
const float enco_sensitivity = 0.25; // how much does the encoder need to turn to update 1 deg c
const int pin_relay = 6; // pin the relay is connected to
const float cushion_temp = 2.0; // how many degrees change is required to change the relay state
char buff[10]; // display output buffer
volatile int enco_prev = 0; // previous encoder direction
volatile long enco_value = 100; // the current encoder value
volatile float target_temp = 0; // the target temperature
boolean setup_mode = false; // are we currently in setup mode, or normal mode?
unsigned long time_now = 0; // current uptime in ms
float current_temp = 0; // current temperature
SoftwareSerial disp(pin_disp_rx, pin_disp_tx); // the display
DHT dht(pin_dht, dht_type); // the temperature sensor
  if (debug) {
    Serial.begin(baud_rate);
  // init display
  disp.begin(baud_rate);
  clearDisplay();
  setBrightness(disp_brightness);
  // init dht
  dht.begin();
  // init encoder
  pinMode(pin_enco_1, INPUT);
  pinMode(pin_enco_2, INPUT);
  pinMode(pin_enco_sw, INPUT);
  digitalWrite(pin_enco_1, HIGH); // turn pullup resistor on
  digitalWrite(pin_enco_2, HIGH); // turn pullup resistor on
  digitalWrite(pin_enco_sw, HIGH); // turn pullup resistor on
  attachInterrupt(0, updateEncoder, CHANGE); // call updateEncoder() when interrupt 0 (pin 2) or 1 (pin 3) change
  attachInterrupt(1, updateEncoder, CHANGE);
  // init relay
  pinMode(pin_relay, OUTPUT);
  switchRelay(false);
  // init system
  target_temp = enco_value * enco_sensitivity;
  writeTargetTemperature();
  delay(3000);
  // check if the encoder switch is being pressed and enter or exit setup_mode
  if (!digitalRead(pin_enco_sw)) {
    setup_mode = !setup_mode;
    updateDisplay();
    delay(1000); // prevent immediately switching back to the other mode
  if (!setup_mode) {
    current_temp = dht.readTemperature(false);
    if (isnan(current_temp)) {
      disp.print("Err ");
      return;
    // we don't want the heater constantly flicking on and off, here we check the
    // current state and compute a "cushioned" target before comparing
    float cushion = cushion_temp / 2.0;
    float cushioned_target = relayState()
      ? target_temp + cushion
      : target_temp - cushion;
    if (debug) { Serial.print("target: "); Serial.println(cushioned_target); }
    switchRelay(current_temp <= cushioned_target);
    updateDisplay();
void updateDisplay() {
  if (setup_mode) {
    writeCurrentTemperature();
void writeCurrentTemperature() {
  // temp is a float. we need an int (well actually a string) to send to the display
  // we multiply by 100 and put a decimal place at position 2
  setDecimals(0b000010);
  sprintf(buff, "%4d", (int) (current_temp * 100));
  disp.print(buff);
  if (debug) { Serial.print("current: "); Serial.println(current_temp); }
void writeTargetTemperature() {
  if (debug) {
    Serial.println(target_temp);
  setDecimals(0b010000);
  sprintf(buff, "T %2d", (int) target_temp);
  disp.print(buff);
void clearDisplay() {
  disp.write(0x76); // clear command byte
void setBrightness(byte value) {
  disp.write(0x7A);  // brightness command byte
  disp.write(value); // (0--->255)
void setDecimals(byte decimals) {
  disp.write(0x77);     // decimal command byte
  disp.write(decimals); // (Apos)(Colon)(Digit 4)(Digit 3)(Digit2)(Digit1)
void updateEncoder() {
  if (!setup_mode) {
    return;
  int msb = digitalRead(pin_enco_1);
  int lsb = digitalRead(pin_enco_2);
  int enco = (msb << 1) | lsb; // convert the 2 pin value to single number
  int sum = (enco_prev << 2) | enco; // compare to the previous value
  // add or subtract based on rotation
  if (sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) { enco_value++; }
  if (sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) { enco_value--; }
  enco_prev = enco; // save for next time
void switchRelay(boolean on) {
  if (on) {
    digitalWrite(pin_relay, HIGH);
    if (debug) { Serial.println("relay: on"); }
  } else  {
    digitalWrite(pin_relay, LOW);
    if (debug) { Serial.println("relay: off"); }
bool relayState() {
  int value = digitalRead(pin_relay);
  bool state = (value == HIGH);
  if (debug) { Serial.println(state ? "relayState() -> on" : "relayState() -> off"); }
  return state;
