Part suggestions needed
Need parts suggestions for:
Expanding the analog inputs to 10.
Good temp sensor that is a good fit for the Arduino.
Thanks
Attach a 4-channel SPI A/D converter to the SPI lines (e.g., MCP3004).
Temp sensors vary quite a bit. Easiest is a thermistor connected as a voltage divider to one of the A/D inputs, or more linear (but more expensive) is an LM35DZ into an analog pin.
The CD4067 is a 16-way CMOS analog multiplexer:
http://web.mit.edu/6.115/www/datasheets/74hc4067.pdf
Thanks, gives me a place to start. :slight_smile:
The MCP3208 is an 8 channel ADC, and it’s trivial to run 2 of them. code for it is in the playground, and I posted code for using multiple units on the forum a few days ago.
-j
Hay great, thanks!
