How would I go about passing a void loop analog read value to a library .h file?
I’ve tried it but it only reads the pot position as soon as I plug the arduino in and does not change once booted up.
arduino main sketch file code;
#include "Arduino.h"
#include "common.h"
#include "synth.h"
#include "serial-in.h"
#include "audio-out.h"
Synth<0>::initialize();
SerialIn<0>::open();
AudioOut<0>::open();
int val = analogRead(A0);
int val1 = analogRead(A1);
int val2 = analogRead(A2);
int val3 = analogRead(A3);
int val4 = analogRead(A4);
while (true) {
if (SerialIn<0>::available()) {
uint8_t b = SerialIn<0>::read();
Synth<0>::receive_midi_byte(b);
int8_t level = Synth<0>::clock();
AudioOut<0>::write(level);
.h file code
#pragma once
// #define private public // for tests
#include "common.h"
// associations of units
#define IOsc Osc
#define IFilter Filter
#define IAmp Amp
#define IEG EG
#define IVoice Voice
#define ISynthCore SynthCore
#include "osc.h"
#include "filter.h"
#include "amp.h"
#include "eg.h"
#include "voice.h"
#include "synth-core.h"
template <uint8_t T>
class Synth {
public:
INLINE static void initialize() {
ISynthCore<0>::initialize();
// Preset
ISynthCore<0>::control_change(OSC_MODE , 0 );
ISynthCore<0>::control_change(OSC_COLOR , val);
ISynthCore<0>::control_change(MOD_RATE , 8 );
ISynthCore<0>::control_change(MOD_DEPTH , val1);
ISynthCore<0>::control_change(LPF_CUTOFF_ENV, val2);
ISynthCore<0>::control_change(LPF_RESONANCE , val3);
ISynthCore<0>::control_change(ENV_A , val4 );
ISynthCore<0>::control_change(ENV_D_R , 1 );
INLINE static void receive_midi_byte(uint8_t b) {
ISynthCore<0>::receive_midi_byte(b);
INLINE static int8_t clock() {
return ISynthCore<0>::clock();
