Pass object (template?) by reference
Hi guys,
i am writing a own class for my own motorcontroller and would like to use the ServoInput library from here: https://github.com/dmadison/ServoInput
My problem now is that i want to pass the ServoInputPin object to my class as reference or to create it dynamicly in my class. Something like that:
Declaration described in documentation:
ServoInputPin<2> servo;
MyMotor.h
class MyMotor
private:
	ServoInputPin<>* MotorInput;
But he ServoInputPin declaration is not a "normal" class for me as beginner :see_no_evil: What does the "<uint8_t>" mean after the class name? And is it possible to plass the "servo" object to a class?
Sry still in the beginning of my c++ learning.
Best regards,
Raphael
that's the template portion. basically the class is parametrised by this. You use that to code once and generate multiple classes at run time.
if you want another class using ServoInputPin, you could use a subclass of ServoInputPin.
template <uint8_t aPin>
class MyMotor : public ServoInputPin< aPin > {
public:
    MyMotor() : ServoInputPin<aPin>() {
        // Constructor for MyMotor
if you don't want inheritance, then you can define another class which would be templated too and you pass that value to the member variable
class MyMotor {
private:
    ServoInputPin<aPin> servo; // ➜ Use the template parameter for the pin
public:
    MyMotor() : servo() {
as in both case MyMotor is "templated" you would do
MyMotor<2> frontLeftMotor;
MyMotor<3> frontRightMotor;
to create instances
