I am building a programmable hot water thermostat.
The menu for my LCD is an array, i’d like to be able to send variables from the menu to a function for setting time values (clock, on times and off times, that sort of thing)
This way i can have one function for hours and one for minutes rather than having an individual function for every hour and every minute of the day.
Here is the menu itself, the whole sketch won’t fit here and i thought this would be the important bit, currently the numbered menu items below refer to hours and minutes and each one runs a function that sets either the clock, an on time or an off time (using if statements). It’d be more streamlined if just 2 functions existed (one for minute and one for hours) that accepting a value from a menu item and set that as the hour or minute.
#include <TimeAlarms.h>
#include <Time.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <nokia_3310_lcd.h>
// Temp/humidity display using nokia 3310 LCD display shield from nuelectronics.com
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//keypad debounce parameter
#define DEBOUNCE_MAX 15
#define DEBOUNCE_ON 10
#define DEBOUNCE_OFF 3
#define NUM_KEYS 5
#define NUM_MENUS 20
#define NUM_MENU_ITEM 6
// joystick number
#define UP_KEY 3
#define LEFT_KEY 0
#define CENTER_KEY 1
#define DOWN_KEY 2
#define RIGHT_KEY 4
// Pin used by Backlight, so we can turn it on and off. Pin setup in LCD init function
#define BL_PIN 7
// menu starting points
#define MENU_X 0 // 0-83
#define MENU_Y 0 // 0-5
int test;
// adc preset value, represent top value,incl. noise & margin,that the adc reads, when a key is pressed
// set noise & margin = 30 (0.15V@5V)
int adc_key_val[5] ={
30, 150, 360, 535, 760 };
// debounce counters
byte button_count[NUM_KEYS];
// button status - pressed/released
byte button_status[NUM_KEYS];
// button on flags for user program
byte button_flag[NUM_KEYS];
// menu definition
static const prog_char menu_items[NUM_MENUS][NUM_MENU_ITEM][16] PROGMEM = {
"Temperature",
"Water Request",
"Program",
"Set Clock",
"Display Time" }
"1",
"1.5",
"2",
"2.5",
"Bath",
"None" }
"Toggle Program",
"Set On",
"Set Off",
"Water Request",
"View Program",
"Main Menu" }
"Set Hour",
"Set Minute",
"Main Menu" }
"Hours 0-5",
"Hours 6-11",
"Hours 12-17",
"Hours 18-23" }
"Minutes 0-5",
"Minutes 5-11",
"Minutes 12-17",
"Minutes 18-23",
"Minutes 24-29",
"Minutes 30-35" }
"0",
"1",
"2",
"3",
"4",
"5" }
"6",
"7",
"8",
"9",
"10",
"11" }
"12",
"13",
"14",
"15",
"16",
"17" }
"18",
"19",
"20",
"21",
"22",
"23" }
"0",
"1",
"2",
"3",
"4",
"5" }
"6",
"7",
"8",
"9",
"10",
"11" }
"12",
"13",
"14",
"15",
"16",
"17" }
"18",
"19",
"20",
"21",
"22",
"23" }
"24",
"25",
"26",
"27",
"28",
"29" }
"30",
"31",
"32",
"33",
"34",
"35" }
"36",
"37",
"38",
"39",
"40",
"41" }
"42",
"43",
"44",
"45",
"46",
"47" }
"48",
"49",
"50",
"51",
"52",
"53" }
"54",
"55",
"56",
"57",
"58",
"59" }
void (*menu_funcs[NUM_MENUS][NUM_MENU_ITEM])(void) = {
temperature,
waterreq,
setProg,
setClock,
displayTime }
shower1,
shower15,
shower2,
shower25,
bath,
none }
toggleProg,
setOn,
setOff,
waterreq,
viewProg,
mainmenu }
setHour,
setMin,
mainmenu }
hour0to5,
hour6to11,
hour12to17,
hour18to23 }
minute0to5,
minute6to11,
minute12to17,
minute18to23,
minute24to29,
minute30to35 }
hour0,
hour1,
hour2,
hour3,
hour4,
hour5 }
hour6,
hour7,
hour8,
hour9,
hour10,
hour11 }
hour12,
hour13,
hour14,
hour15,
hour16,
hour17 }
hour18,
hour19,
hour20,
hour21,
hour22,
hour23 }
Any ideas?
Thanks
