slayes
November 9, 2022, 7:41am
1
Hello,
I don't understand why this codes doesn't work as instead
This code is working well :
static const char *url = "https://xxxxx/file_v2_1_0_199.bin ";
HttpsOTA.onHttpEvent(HttpEvent);
HttpsOTA.begin( url, server_certificate );
This code, no
#include <ArduinoJson.h>
StaticJsonDocument srvActions;
DeserializationError error = deserializeJson(srvActions, msg);
if (error) { Serial.print(F("deserializeJson() failed: ")); Serial.println(error.f_str()); return; }
const char* action = srvActions["action"];
const char* datas = srvActions["value"];
appUpdate( String( datas ) );
void appUpdate( String fwFileName ) {
Serial.println( fwFileName );
Serial.println( fwFileName.length());
int str_len = fwFileName.length() + 1;
char char_array[ str_len ];
fwFileName.toCharArray(char_array, str_len);
static const char *url = char_array;
Serial.print("url : ");Serial.println( url);
See bellow the console result :
08:34:15.852 -> 44
08:34:15.852 -> url : https://xxxxxxxx/file_v2_1_0_199.bin
08:34:15.852 -> E (5217) HTTP_CLIENT: Error parse url e⸮?⸮
Thanks in advance for your help
J-M-L
November 9, 2022, 7:52am
2
Memory issue ?
Try
void appUpdate( String& fwFileName ) {
HttpsOTA.begin( fwFileName.c_str(), server_certificate );
There is no reason to allocate all the memory you have…
This supposed you are passing a String to the function.
If you pass something within double quotes then just do
void appUpdate( const char * fwFileName ) {
HttpsOTA.begin( fwFileName, server_certificate );
Édit: just seen you call appUpdate( String( datas ) );
Why don’t you just call with the const char* you got ➜ appUpdate( datas ); and use the second version of the function given above ….
So much memory used for nothing:
you have a const char *
you allocate a String with its content
you duplicate that String to call the function
in the function you duplicate it again to have a char array buffer
then you allocate a const char * pointer to point at the start of the buffer (the buffer name would have been good enough)
That’s absurd given you had the const char* to start with…
slayes
November 9, 2022, 8:10am
3
Thanks for you reply.
It was my original code and console result :
void wsPrepare(char * msg){//Coming from WebSocket
appUpdate( datas );
Serial.printf("url : %s\n", fwFileName);
09:03:25.993 -> url : https://xxxxxx/file_v2_1_0_199.bin
09:03:25.993 -> E (5299) HTTP_CLIENT: Error while setting default configurations
09:03:25.993 -> E (5304) esp_https_ota: Failed to initialise HTTP connection
I don't understand/know how to debug this issue. It's working only if the url variable has been declared in the "appUpdate" function like :
static const char *url = "https://xxxxxx/file_v2_1_0_199.bin ";
J-M-L
November 9, 2022, 8:18am
4
Did you try what I proposed?
Don’t print or do anything else in the function
Possibly verify your internet connection is still active
Post full code
slayes
November 9, 2022, 8:37am
5
Need a moment to write a short sample code, my actual project is over 1000 lines.
appUpdate( datas );
But the code see below is working
static const char *url = "https://xxxxxx/file_v2_1_0_199.bin";
appUpdate( url );
I don't understand because "datas" variable is a pointer of char array :
J-M-L
November 9, 2022, 8:40am
6
That’s an issue you need to dig into
slayes
November 9, 2022, 8:52am
7
May be the problem is linked with the JSON, because
This code doesn't work :
if (msg == "") return;
Serial.print("WS >> wsPrepare ");
//Serial.println (msg);
Serial.printf("datas : %s\n", datas);
appUpdate( datas);
09:46:20.005 -> url : https://xxxxxx/file_v2_1_0_199.bin
09:46:20.005 -> E (5299) HTTP_CLIENT: Error while setting default configurations
09:46:20.005 -> E (5304) esp_https_ota: Failed to initialise HTTP connection
And this code is working :
Serial.printf("url: %s\n", datas);
appUpdate( url);
09:47:41:214 -> url : https://xxxxxx/file_v2_1_0_199.bin
09:47:41:214 -> App >> Mise à jour : Http Event On Connected
J-M-L
November 9, 2022, 9:04am
8
may be there are invisible characters
try to print
Serial.printf("datas : [%s]\n", datas);
J-M-L
November 9, 2022, 9:29am
10
you might have a buffer overflow somewhere than corrupts the http connection
slayes
November 9, 2022, 9:44am
11
Arf... Is there a way/method to trace this issue ?
J-M-L
November 9, 2022, 9:45am
12
look at the whole code for array allocation
slayes
November 9, 2022, 10:12am
13
I tried to remove all unnecessary code.
#include <Arduino.h>
#include <ArduinoUniqueID.h>
#include <Preferences.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <WebSocketsClient.h>
#include "HttpsOTAUpdate.h"
#include <jled.h>
WebSocketsClient webSocket;
const size_t CAPACITY = JSON_OBJECT_SIZE(4) + JSON_ARRAY_SIZE(3);
StaticJsonDocument<CAPACITY> doc;
JsonArray jsonCmd = doc.to<JsonArray>();
StaticJsonDocument<CAPACITY> srvActions;
wsInit();
ledSetup.Stop();
ledCur.Update();
ledCur.Update();
webSocket.loop();
wsSend();
void wsInit(){
Serial.printf("WS >> Initialisation sur %s:%i\n", wsIP, wsPort);
webSocket.begin( wsIP, wsPort, "/");
webSocket.onEvent(wsEvent);
webSocket.setAuthorization(............);
webSocket.setReconnectInterval(5000);
webSocket.enableHeartbeat(15000, 5000, 2);
void wsSend(){
if (!wsIsConnected || jsonCmd.size() == 0) return;
String output;
serializeJson(doc, output);
output = "{\"" + (isConfigured ? String("publicKey") : String("uniqueId")) + "\":\"" + (isConfigured ? publicKey : uniqueId) + "\", \"version\": \"" + SKETCH_VERSION + "\", \"actions\": " + output + "}";
Serial.printf("WS >> wsSend : %s\n", output.c_str());
webSocket.sendTXT(output);
jsonCmd.clear();
void wsEvent(WStype_t type, uint8_t * payload, size_t length) {
Serial.print("WS >> ");
switch(type) {
case WStype_TEXT:
Serial.printf("wsReceived : %s\n", payload);
if ( String((char *) payload).startsWith("{") ) wsPrepare((char *) payload);
//Serial.println(msg);
actions act = actionSwitch( srvActions["action"] );
switch (act){
case 4: //UPDATE
Serial.printf(">> Action : %s\n", action);
ledCur.Stop();
ledCur = JLed(PIN_RED).Blink(500, 500).Forever();
Serial.printf("datas length : %s - %i\n", datas, strlen (datas));
appUpdate( datas );
static HttpsOTAStatus_t otastatus;
static const char *server_certificate = ..............
void HttpEvent(HttpEvent_t *event) {
Serial.print("App >> Mise à jour : ");
J-M-L
November 9, 2022, 10:24am
14
so many missing parts, so hard to say. usually the bug is where you don't expect it...
you can't test a cString like this
do
if (*msg == '\0') return; // message is empty
also in this function
you are not guaranteed that the payload ends up with a null char, so you can't take for granted you have a cString when you do
➜ there might be a few non printable bytes at the end that you don't see when you print things out.
do something like
case WStype_TEXT:
Serial.write("wsReceived :");
Serial.write(payload, length);
if (*payload == '{' ) wsPrepare((char* ) payload, length);
and change the function
void wsPrepare(char * msg, size_t length) {
if (length == 0) return;
DeserializationError error = deserializeJson(srvActions, msg, length);
if (error) {
return;
switch (act) {
case 4: //UPDATE
ledCur.Stop();
appUpdate( datas );
slayes
November 9, 2022, 11:56am
15
Thanks for your comment
Unfortunally, it's not better.
By any chance, is it possible that «srvActions["value"]» doesn't contain a null terminating ?
I don't succeed to add it manually with strcopy
J-M-L
November 9, 2022, 12:27pm
16
no it will have one set by the ArduinoJSON library. what might happen though is that the library will read the data until it finds a null char, which might not be there at the end of the payload
One way to find out possibly is by looking at the char count
when you do
➜ how many characters do you have in url ?
then when you go for the JSON, how many characters do you see in
they would need to match
slayes
November 9, 2022, 1:14pm
17
I already checked this part, it's correct :
const char *urlTest = "https://xxxxxx/file_v2_1_0_199.bin "
Serial.printf("urlTest length : %s - %i\n", urlTest, strlen (urlTest));
14:11:09.874 -> datas length : https://xxxxxx/file_v2_1_0_199.bin - 44
14:11:09.874 -> urlTest length : https://xxxxxx/file_v2_1_0_199.bin - 44
J-M-L
November 9, 2022, 1:15pm
18
really weird. Hard to debug without the full system on hand...
I would try to write a small code using the JSON and making the request
slayes
November 9, 2022, 1:59pm
19
I'll write a short project to share with only the feature used for this action.
As I can see both variable have the same length and type. Is there a way to do a loop to display all ASCII codes of all caracters ?
J-M-L
November 9, 2022, 2:11pm
20
sure a simple while loop until you find the null char would do
but that's what print does. if you can count 44 characters on screen for https://xxxxxx/file_v2_1_0_199.bin then you've seen them all
the issue is likely somewhere else. could you print the string and its length as well within the function and not when calling it.
