Pass reference/pointer to struct?!
Hi there!
I have a multiple of byte arrays:
static const PROGMEM byte  bytes1[][3] = {
{B00000000, B00010111, B00000000}
,{B00000011, B00000000, B00000011}
,{B00011111, B00001010, B00011111}
static const PROGMEM byte  bytes2[][4] = {
{B0110000, B00010111, B00000000, B00000000}
,{B00000011, B00001100, B00000001, B00000000}
,{B00010011, B00001000, B00011001, B00000000}
static const PROGMEM byte  bytes3[][2] = {
{B00001100, B00010011}
,{B00010111,B00001100}
,{B00000011, B0000000}
,{, B00001000, B00011001}
I want to swap these byte arrays into this struct (where the array should be “byteArray”)
struct MyBytes {
      int width;
      byte * byteArray;
    MyBytes activeBytes;
with this code:
setByteArray(int theByteArray)
  if(theByteArray == 1)
 activeBytes.width = 3
 activeBytes.byteArray = bytes1
if(theByteArray == 2)
 activeBytes.width = 4
 activeBytes.byteArray = bytes2
if(theByteArray == 3)
 activeBytes.width = 2
 activeBytes.byteArray = bytes3
After that I want to use the struct in another method and read back these values stored in PROGMEM (ignore the character - 0x20, it works when I use is without the struct: bitBuffer = pgm_read_byte(&font_5x3[character - 0x20]); without any problems):
*draw(char *text)
while(*text)
   char character = *text++;
   byte bitBuffer[15];
   for(int i = 0; i < activeBytes.width; i++)
     bitBuffer[i] = pgm_read_byte(&activeBytes.byteArray[character - 0x20][i]);
_
*_ _*Unfortunately I get this error:*_ _*_
In member function 'void draw(char)’:
error: invalid types ‘byte {aka unsigned char}[int]’ for array subscript
exit status 1
Any ideas how to accomplish what I want?
Thanks in advance!
First, you need to understand what the type of the thing you want to point to is.
This is an array of arrays of bytes. To point to it, the variable type needs to be byte **, not byte *.
Thanks for your reply!
I want to use a struct to point to an array of byte arrays, exactly :slight_smile: I dont want to copy the array to the struct I just want to reference to it, swap the reference to the array of byte arrays when needed and then use it in another method.
In detail: I have a font array which is an array of byte arrays. These have different lengths so I want to use a struct to keep track of this.
When I change the struct to:
struct MyBytes {
      int width;
      byte ** byteArray;
I get this error:
cannot convert 'const byte (*)[96][3] {aka const unsigned char (*)[96][3]}' to 'byte** {aka unsigned char**}' in assignment
at this line:
You want to point to the address where the array lives.
activeBytes.byteArray = &bytes1;
asuryan:
*draw(char *text)
while(*text)
   byte bitBuffer[15];
exit status 1
invalid types ‘byte {aka unsigned char}[int]’ for array subscript*
*_ _*Any ideas how to accomplish what I want?*_ _*Thanks in advance!*_ _*[/quote]*_ _*The compiler doesn't know how to treat a bye pointer (activeBytes.byteArray) as a two-dimensional array. It can treat it as a 1-dimensional array of bytes but you have to do the two-dimensional indexing math manually:*_ _*
*      bitBuffer[i] = pgm_read_byte(&activeBytes.byteArray[(character - 0x20) * activeBytes.width + i);
_
```*_
