Passing a command between two arduino via serial
Hi all. I’m trying to set up an arrangement by which arduinos talk to one another via a soft serial. Eventually, four arduinos will cascade commands in a chain. For now, just as a proof of concept I’m trying to get two arduinos to ping-pong a 12-char command between each other. Here’s the code I’m using…
#include <SoftwareSerial.h>
SoftwareSerial ss(5, 6);
int count = 0;
char commandString[12] = “A1234567890A”;
ss.begin(9600);
if (Serial.available() > 0) { // SENDING ANY SINGLE CHARACTER TRIGGERS THE TEST
Serial.read();
Serial.println(“GO!”);
transmit();
if(ss.available()) {
for(int i=0;i<12;i++) {
commandString*=ss.read();*
  • Serial.print("received: ");*
  • Serial.println(commandString);*
  • transmit();*
void transmit() {
  • count++;*
  • if(count<9) { *
  • //sprintf (commandString, “A123456789%01iA”, count);*
  • ss.print(commandString);*
  • Serial.print("transmitted: ");*
[/quote]
But what I’m getting back is garbled…
> GO!
> transmitted: A1234567890A
> received: Ansmitted: A
> transmitted: Aived: 81234567eceived: 90A
> tran90A
> transmitted: 890A
> 567890A
> received: Ansmi
> tratted: A1234567890
> transmitted: 7890
> received: AAansmitted: AAd: received: : 9
Any clues?
Any clues?
Don't try to read data that isn't there (yet)
Gotcha - thanks (and doh). Code below works a treat…
int count = 0;
ss.begin(9600);
Serial.read();
transmit();
int i=0;
while(i<12) {
if(ss.available()){
  • i++;*
  • transmit();*
void transmit() {
  • count++;*
  • if(count<9) { *
  • sprintf (commandString, “A123456789%01iA”, count);*
[/quote]
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
The technique in the 3rd example will be the most reliable.
You can send data in a compatible format with code like this
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
…R
