I am just learning BLE and have modified a sketch in order to pass the temperature recorded by the Nano 33 BLE Sense over BLE as a floating point number. When I connect via my Android app "nRF Connect" the correct values appear in the serial monitor but in the app the values appear to be random values such as -323,71°C and 46.75°C and 223.5% and 26,43%. Here is the sketch:
#include <ArduinoBLE.h>
#include <Arduino_HTS221.h>
#include <Arduino_LSM9DS1.h>
BLEService sensorService("181A");
BLEFloatCharacteristic temperatureSensorLevel("2A6E", BLENotify );
BLEFloatCharacteristic humiditySensorLevel("2A6F", BLENotify );
float oldTemperature = 0;
float oldHumidity = 0;
//while (!Serial);
delay(10);
// set the LEDs pins as outputs
pinMode(LEDR, OUTPUT);
pinMode(LEDG, OUTPUT);
pinMode(LEDB, OUTPUT);
// turn all the LEDs off
digitalWrite(LEDR, LOW);
digitalWrite(LEDG, HIGH);
digitalWrite(LEDB, HIGH);
if (!HTS.begin()) {
Serial.println("Failed to initialize humidity temperature sensor!");
while (1);
pinMode(LED_BUILTIN, OUTPUT);
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
BLE.setLocalName("SteveTempHumidity2");
BLE.setAdvertisedService(sensorService);
sensorService.addCharacteristic(temperatureSensorLevel);
sensorService.addCharacteristic(humiditySensorLevel);
BLE.addService(sensorService);
temperatureSensorLevel.writeValue( oldTemperature);
humiditySensorLevel.writeValue( oldHumidity);
BLE.advertise();
Serial.println("Bluetooth device active, waiting for connections");
BLEDevice central = BLE.central();
if (central) {
Serial.print("Connected to central: ");
Serial.println(central.address());
//digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LEDR, HIGH);
digitalWrite(LEDB, LOW);
while (central.connected()) {
//long currentMillis = millis();
updateHumidityLevel();
delay (300);
digitalWrite(LED_BUILTIN, LOW);
Serial.print("Disconnected from central: ");
void updateHumidityLevel() {
float temp, hum;
temp = HTS.readTemperature();
hum = HTS.readHumidity();
Serial.print("********");
Serial.print(temp);
if (temp != oldTemperature) {
temperatureSensorLevel.writeValue(temp);
oldTemperature = temp;
if (hum != oldHumidity) {
humiditySensorLevel.writeValue(hum);
oldHumidity = hum;
Serial.print("Temp = ");
Serial.print(temp);
Serial.println("°C");
Serial.print("Humidity = ");
Serial.print(hum);
Serial.println("%");
Even if you transfer the binary float representation correctly, keep in mind that there are different representations on different machines (one of them is byte order: big or little endian) and conversions are sometimes required.
I changed the float values to int and the BLE characteristics to BLEIntCharacteristic but now I get no value at all in the "nRF Connect" app. I have been trying for over two days now to send the temperature data from the Nano 33 BLE sense over BLE as anything other than a string. This is most frustrating. Any tips would be greatly appreciated.
You can always convert the int to a string and send that.
That's what the original sketch did, but I want to use the value on another Arduino acting as the BLE Central. It is much easier to write a sketch manipulating an integer or float than a sring. Ie >, <, +,*. Which is why I want to send a number.
I can not confirm your issue. I don't have your sensors, but when I use a set value in the sketch I can see them in nrfConnect (and LightBlue, which I prefer). Are you seeing the correct sensor values in you serial output?
BLEIntCharacteristic temperatureSensorLevel("2A6E", BLENotify);
BLEIntCharacteristic humiditySensorLevel("2A6F", BLENotify);
int oldTemperature = 0;
int oldHumidity = 0;
//while (!Serial);
delay(10);
//if (!HTS.begin()) {
// Serial.println("Failed to initialize humidity temperature sensor!");
// while (1);
if (!BLE.begin()) {
while (1);
BLE.advertise();
if (central) {
delay (300);
static int temp = 23;
static int hum = 55;
//temp = HTS.readTemperature();
//hum = HTS.readHumidity();
temp = temp +1; //increment value for testing
oldHumidity = hum;
Serial.print(temp);
Serial.print(hum);
Yes I am getting the correct (integer) sensor values in the serial monitor. I left the app nRF Connect running on my phone and after a while I noticed that the humidity value was showing correctly and a few minuteslater the temperature value appeared correctly too. I restarted the Nano and reconnected but the values have not appeared yet.
Using your code I still had the same problems. I changed the BLEIntCharacteristics from BLENotify to BLERead and got the values of 24°C (23+1) and 55% in the app! Great! I reset the temp and hum to int and uncommented the following two lines
I don't know why you are having issues with Notify. I would try using Light Blue and use the "subscribe" button. I think I one point I did have issues with Notify (without Read) and nrfConnect
When I first started with your program I thought Read was going to be needed as well. But I later determined that Notify alone was working OK.
