I need to pass a function with its variables to the simple timer library and i keep getting errors about passing a void function. when I set it to int only the return value is passed and then the loop doesn’t work.
Snippet of the example.
void activateAlarm(int alarmNumber, bool startup){
if(!startup){
if(stateAlarm[alarmNumber]){//Reset Alarm
if(triggerAlarm){//If the alarms are active
digitalWrite(alarmPins[alarmNumber], LOW);
timer.setTimeout(randomize(meanDeactivateAlarm), activateAlarm(alarmNumber, false));
stateAlarm[alarmNumber] = false;
Serial.println("Alarm Off" + word(alarmNumber));
else{//Trigger alarm
digitalWrite(alarmPins[0], HIGH);
timer.setTimeout(randomize(meanActivateAlarm), activateAlarm(alarmNumber, false));
stateAlarm[alarmNumber] = true;
Serial.println("Alarm On" + word(alarmNumber));
else{ //Initiate Startup
//Serial.println("Starting Alarm" + word(alarmNumber));
digitalWrite(alarmPins[alarmNumber], HIGH);
timer.setTimeout(randomize(10), activateAlarm(alarmNumber, false));
full code
#include <SimpleTimer.h>
//Declare Switch pins
const int randomSwitchPin = 2;
const int alarmSwitchPin = 3;
const int tamperSwitchPin = 4;
const int troubleSwitchPin = 5;
//Declare Mean Time
const unsigned long meanActivateAlarm = 1000;
const unsigned long meanActivateTamper = 1000;
const unsigned long meanActivateTrouble = 1000;
const unsigned long meanDeactivateAlarm = 1000;
const unsigned long meanDeactivateTamper = 1000;
const unsigned long meanDeactivateTrouble = 1000;
bool constantTime = false; //False for randomized times, True for static times. tied to switch
bool triggerAlarm = true; //Tied to switch, specifies whether or not to tigger the alarm signals
bool triggerTamper = true; //Tied to switch, specifies whether or not to tigger the tamper signals
bool triggerTrouble = true; //Tied to switch, specifies whether or not to tigger the trouble signals
int alarmPins[] = {22,25,28,31,34,37,40,43,46,49}; //Pin definitions for the alarm signal. First is alarm 1, second alarm 2, etc..
int tamperPins[] = {23,26,29,32,35,38,41,44,47,50}; //Pin definitions for the tamper signal. First is alarm 1, second alarm 2, etc..
int troublePins[] = {24,27,30,33,36,39,42,45,48,51}; //Pin definitions for the trouble signal. First is alarm 1, second alarm 2, etc..
int numberOfSets = 10;
bool stateAlarm[10], stateTamper[10], stateTrouble[10]; //Declare Alarm State Trackers
SimpleTimer timer;
void setup(){
Serial.println("Hello World");
for(int i=0; i < numberOfSets; i++){ //Declare all alarm pins and Startup system
pinMode(alarmPins[i],OUTPUT);
activateAlarm(i,true);
for(int i=0; i < numberOfSets; i++){ //Declare all a tamper pins and Startup system
pinMode(tamperPins[i],OUTPUT);
activateTamper(i,true);
for(int i=0; i < numberOfSets; i++){ //Declare all trouble pins and Startup system
pinMode(troublePins[i],OUTPUT);
activateTrouble(i,true);
pinMode(alarmSwitchPin,INPUT_PULLUP);
pinMode(tamperSwitchPin, INPUT_PULLUP);
pinMode(troubleSwitchPin, INPUT_PULLUP);
pinMode(randomSwitchPin, INPUT_PULLUP);
randomSeed(analogRead(0)); //Seed random number generator
srand(random(2000000000));
Serial.println("Startup Finished");
void loop(){
triggerAlarm = !digitalRead(alarmSwitchPin);
triggerTamper = !digitalRead(tamperSwitchPin);
triggerTrouble = !digitalRead(troubleSwitchPin);
constantTime = !digitalRead(randomSwitchPin);
timer.run();//run the timer
if(!startup){
timer.setTimeout(randomize(meanDeactivateAlarm), *activateAlarm(alarmNumber, false));
timer.setTimeout(randomize(meanActivateAlarm), *activateAlarm(alarmNumber, false));
timer.setTimeout(randomize(10), *activateAlarm(alarmNumber, false));
void activateTamper(int tamperNumber, bool startup){
if(!startup){
if(stateTamper[tamperNumber]){//Reset Tamper
if(triggerTamper){//If the alarms are active
digitalWrite(tamperPins[tamperNumber], LOW);
timer.setTimeout(randomize(meanDeactivateTamper), activateTamper(tamperNumber, false));
stateTamper[tamperNumber] = false;
else{//Trigger Tamper
digitalWrite(tamperPins[tamperNumber], HIGH);
timer.setTimeout(randomize(meanActivateTamper), activateTamper(tamperNumber, false));
stateTamper[tamperNumber] = true;
timer.setTimeout(randomize(10), activateTamper(tamperNumber, false));
void activateTrouble(int troubleNumber, bool startup){
if(!startup){
if(stateTrouble[troubleNumber]){//Reset Trouble
if(triggerTrouble){//If the troubles are active
digitalWrite(troublePins[troubleNumber], LOW);
timer.setTimeout(randomize(meanDeactivateTrouble), activateTrouble(troubleNumber, false));
stateTrouble[troubleNumber] = false;
else{//Trigger trouble
digitalWrite(troublePins[troubleNumber], HIGH);
timer.setTimeout(randomize(meanActivateTrouble), activateTrouble(troubleNumber, false));
stateTrouble[troubleNumber] = true;
timer.setTimeout(randomize(10), activateTrouble(troubleNumber, false));
unsigned long randomize(unsigned long mean){
if(constantTime == false && mean != 1000){
double U = (double) ((double) rand()/ (double) RAND_MAX);
unsigned long randomVariable = -1*log(U)*mean;
//if(randomVariable < 11000){
//Serial.print(randomVariable);
//randomVariable = randomize(mean);
return randomVariable;
else{
return mean;
