passing a variable to another event
there is a variable in receiveEvent(); which is called “x” in the attached file.
I want this x be subtracted from value_1 which is in the main loop event. what should I do to pass the “x” variable to the main loop so that the calculation can be done?
i2c_slave_passvar.ino (428 Bytes)
emrahyigit: there is a variable in receiveEvent(); which is called "x" in the attached file. I want this x be subtracted from value_1 which is in the main loop event. what should I do to pass the "x" variable to the main loop so that the calculation can be done?
make Value_1 a global variable and the function will have access to it.
See the comments in the code. Have a look at this page that has information on variable scope in C++.
#include <Wire.h>
byte x = 0;  // create a global variable for x,  the entire sketch has
              // access to global variables
  Wire.begin(1);
  Wire.onReceive(receiveEvent);
  byte value_1=analogRead(A1);
  delay(100);
  result=Value_1-x;
  if (Result>........
void receiveEvent(int howMany) {
  while (1 < Wire.available()) {
    char c = Wire.read();
    Serial.print(c);
  x = Wire.read();   // remove the type definition. Otherwise creates another variable
                     // named x
  Serial.println(x);
thank you very much. the key sentence for me is
// named x
Serial.println(x);
because İ also put the type definition in the loop.
