Passing Alexa Moisture Sensor Data
I'm trying to make a system where Alexa can tell me what moisture percentage my plants are at, but I'm not sure how to pass the data through IOT and the Arduino Alexa skill.
I receive data from a moisture sensor and map it to 0-100 (representing moisture percent) as an int. From there I'm not sure how to pass it to Alexa, as ints aren't an accepted data type, and the closest accepted data type seems to be a temperature sensor reading.
Any help is appreciated.
Here is my code:
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/e4b4ee50-b7e5-4f2e-bae5-17fb775cbdb5
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  CloudTemperatureSensor percentageHumidity;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#define moistIn A0
const long wet = 300;
const long dry = 780;
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  while(!Serial);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  // Your code here
long moisture= analogRead(moistIn); //Read sensor Val
int percentageHumidity = map(moisture, wet, dry, 100, 0); //Map to a percentage value
Serial.println(moisture);
Serial.print("Soil is at ");
Serial.print((percentageHumidity));
Serial.print("% moisture");
delay(3000);       //Print soil moisture % every 3 seconds
Try here
