Can anyone direct me to an example which shows how to pass an array form a subroutine to main void loop. Thanks.
This is one risky way of doing it:
byte array = {1,2,3,4};
byte* getArray(){ return &array[0]; }
byte* arr = getArray();
for(byte i=0; i<4; i++){
Serial.println(*(arr+i));
}void loop(){
Or, as far as I remember from my C/C++ days, pass a buffer and its size as the function arguments, something like this (not tested though):
byte array[] = {1, 2, 3, 4, 5};
int arraySize = 5;
// copy the array elements to the given buffer;
// return the number of elements copied;
int getArray(byte* pBuffer, int bufferSize)
int nRet = min(bufferSize, arraySize);
for (int i=0; i<nRet; i++)
pBuffer[i] = array[i];
return nRet;
void callGetArray()
// allocate a buffer;
byte buffer[3]={0};
// get array elements in this buffer;
int howMany = getArray(buffer, 3);
// should return 3;
// allocate a second, larger, buffer;
byte bufferBig[10]={0};
howMany = getArray(bufferBig, 10);
// should return 5;
AlphaBeta, you may already be aware of this, but &array[0] and array are equivalent. The name of an array variable IS a pointer to its first element. That’s why foo[] and and foo[5] and foo* are interchangeable as argument types.
byte* getArray() { return array; }
Your recommended code returned the address of a global array, which is perfectly safe and not risky at all. If the array were allocated as a stack variable inside the getArray() function, that would be bad.
You can use this scheme to good effect in animation:
#define LOOP 8
#define IMAGE 8
static byte _special_frame[IMAGE] = { ... };
static byte _looping_frames[LOOP][IMAGE] = { ... };
byte* getBitmapData(int framenum)
if (framenum < 0 || framenum >= LOOP)
return _special_frame;
return _looping_frames[framenum];
Thanks very much. I will try this and get back to you. I greatly appreciate the response.
Yes, I am aware, but I like to emphesize this for later viewing of my code. :) [And for potentional readers]
My reason for saying it is risky is that you do not get any indication of the array length, and could easily go out of bounds. And I always presume that functions will be implemented in a class eventually :)
Your example uses defines for length, which eliminates the problem [at least at global scope]
