Passing array to method different length?!
I got a problem passing an byte array to a method:
byte letterA[5] = { B11111111,B11000011,B11111111,B11000011,B11000011 };
drawBitmap(1,1,letterA);
int bitmapSize = sizeof(letterA);
Serial.println("outside");
Serial.println(bitmapSize);
void drawBitmap(uint8_t x, uint8_t y, byte bitmap[])
  int bitmapSize = sizeof(bitmap);
  Serial.println("inside");
  for(int i=0;i<bitmapSize;i++)
    ledBuffer[i] = bitmap[i];
The output is as follows:
outside
5
inside
2
Why does my array shrink to 2 inside the method?
Thanks in advance!
Short "answer": when passing array to function, always pass along the length of it too.
Answer to your question: 2 is the size of the pointer to the array not the array length. Why you get a 5 before? because at compile time, the compiler "knows" and replaces that sizeof() = 5.
Thanks for your reply!
So the function need to look like this?
void drawBitmap(uint8_t x, uint8_t y, byte bitmap[5])
or may I need to make it like this:
void drawBitmap(uint8_t x, uint8_t y, byte bitmap[], int bitmapSize)
exactly
