I'm trying to pass an int from a robot's sonar sensor into its function for controlling the motors. The robot has 2 front-facing sensors - one on the left and one on the right side. In my code, the closer the robot is to an object on the right side, the slower the left motors will turn, thus creating a speed differential.
The problem I'm facing in my code is that I'm trying to pass the value of a sonar to the motor function, but I am getting an error message, as shown in the attached image.
The part of my code where I'm getting the error is passing the left sonar value, 'sonar_value[0]' and the right sonar value, 'sonar_value[1]' into the function class members 'Right_Differential' and 'Left_Differential', respectively, as shown here at the bottom of my (abridged) code.
I am unsure of how to handle the errors, and not sure what needs to be fixed since I think I properly declared the 'sonar_value' properly as an int.
// Libraries
#include <NewPing.h> // Sonar library
#include <AFMotor.h> // AF Motor shield library
// Sonar Declarations
// SET UP PINS & ROBOT INFO
#define SONAR_NUM 2 // Number or sensors
#define MAX_DISTANCE 500 // Maximum distance (in cm) to ping.
// or should it be 200?
// Sensor object array, defines how to use the pins
NewPing sonar[SONAR_NUM] =
// (trigger pin, echo pin, and max distance to ping)
NewPing(18, 19, MAX_DISTANCE), // sensor 1
NewPing(20, 21, MAX_DISTANCE), // sensor 2
int sonar_value[SONAR_NUM];
/* array format: sonar_value[left sonar][right sonar]
could be placed in class sonar, public, but couldn't then be called from loop()
//GLOBAL VARIABLES for Sonars
// these are placed to because they need to be called in main loop()
// they could have been defined within their class, but then couldn't use variables outside of the class in loop()
// threshold for sonar to detect obstacle, inches
const static int threshold = 15;
int error_value = 395;
/* Note: This number is set in the NewPing.h file, #define NO_ECHO 99999999,
which translates to 395 inches, which is a garbage value since sensor would never see it
Note: default value to return was 0, but I modified the NewPing.h file.
Note: If object is covering either "eye" of sensor, an error will also be returned since object inhibited a returned pulse
//Motor Declarations
// define wheels (individual)
// front wheels
AF_DCMotor Motor_Left_Front(4, MOTOR34_1KHZ); // motor 4
AF_DCMotor Motor_Right_Front(3, MOTOR34_1KHZ); // motor 3
// rear wheels
AF_DCMotor Motor_Left_Rear(1, MOTOR12_64KHZ); // motor 1
AF_DCMotor Motor_Right_Rear(2, MOTOR12_64KHZ); // motor 2
/********** GLOBAL VARIABLES for Motors **********/
int motor_delay = 10; // ms time delay, time motors should run for
// Autonomous Mode uses 20ms, which is set there to change
int differential_speed;
// Other Declarations
// LEDs, used for mode status
const int ledPin = 23; // LED is connected to pin 23, STATUS
const int ledPin2 = 22; // yellow LED, flickering LED
// These variables CAN change
int auto_code = -1; // default
int incomingByte; // a variable to read incoming serial data into
int ping_once = 0; /* done so that robot will not always ping on manual motors to stop,
because next time around, x > 1, and is reset
each time switch from autonomous mode
// BOOLEAN VARIABLES
bool autonomous_code = false; // default
// CLASS: Sonar
class Sonar
public:
void Setup_Sonars() // run once at setup
// nothing is currently here
void Read_Sonars()
// Loop through all the sensors
for (int i = 0; i < SONAR_NUM; i++)
int value = sonar[i].ping_in(); // ping each sensor in array
sonar_value[i] = value; // write current sensor's value into array slot for that sensor
delay(80); //time between sensor pings (29ms is about the min to avoid cross-sensor echo). Larger time for debugging
// print values
Serial1.print(i);
Serial1.print("=");
Serial1.print(sonar_value[i]);
Serial1.print("in | ");
Serial1.println();
private:
// CLASS: Motors
class Motors
public:
void Setup_Motors()
// scale % into pwm range
int pwm = map(speed, 0, 100, 0, 255);
// takes range of 0-255 and maps it to 0-100 for variable 'speed'
// front wheels
Motor_Left_Front.setSpeed(pwm);
Motor_Right_Front.setSpeed(pwm);
// rear wheels
Motor_Left_Rear.setSpeed(pwm);
Motor_Right_Rear.setSpeed(pwm);
// make sure motors are not triggered at start
Drive_State(RELEASE); // stop
// DIFFERENTIAL - TURN LEFT (Right sonar triggered)
void Left_Differential(int sonar_value[1])
differential_speed = autonomous_speed - (autonomous_speed *( (threshold - sonar_value[1]) / (threshold - 1) ));
// front wheels
Motor_Left_Front.run(differential_speed);
Motor_Right_Front.run(FORWARD);
// rear wheels
Motor_Left_Rear.run(differential_speed);
Motor_Right_Rear.run(FORWARD);
// DIFFERENTIAL - TURN RIGHT (Left sonar triggered)
void Right_Differential(int sonar_value[0])
differential_speed = autonomous_speed - (autonomous_speed *( (threshold - sonar_value[0]) / (threshold - 1) ));
// front wheels
Motor_Left_Front.run(FORWARD);
Motor_Right_Front.run(differential_speed);
// rear wheels
Motor_Left_Rear.run(FORWARD);
Motor_Right_Rear.run(differential_speed);
private:
static const int speed = 100; // % of maximum speed, used for mapping
static const int manual_speed = 255; // % of maximum speed
static const int autonomous_speed = 255 * 0.4 ; // % of manual speed
CLASSES SETUP, FORM:
Class [space] Object ;
// sonar class
Sonar sonar_function;
// motors class
Motors motors_function;
Serial1.begin(9600); // set up Serial library at 9600 bps
pinMode(ledPin, OUTPUT); // Set the LED pin as output
pinMode(ledPin2, OUTPUT);
// Motors setup
motors_function.Setup_Motors();
// Sonar setup - currently not used
sonar_function.Setup_Sonars();
//Serial.println(incomingByte);
// AUTONOMOUS MODE
if (autonomous_code == true)
// read sonar
sonar_function.Read_Sonars();
// AUTONOMOUS Movement
// check if either sonar reads below threshold
if ((sonar_value[0] < threshold) || (sonar_value[1] < threshold)) //&& (sonar_value[0] > 0) && (sonar_value[1] > 0))
// error checker. prevents the possibility of an error of no ping returned when no object is near.
if ((sonar_value[0] != error_value) && (sonar_value[1] != error_value))
// BOTH left & right sonars are triggered, indicating a wall
if ((sonar_value[0] < threshold) && (sonar_value[1] < threshold))
// back up + turn, or escape (random?)?
motors_function.Drive_State(BACKWARD); // backward
Serial.print("A");
// LEFT sonar is triggered
else if (sonar_value[0] < threshold)
/* // turn right
motors_function.Right_Turn();
Serial.print("B");
// differential, turn RIGHT
motors_function.Right_Differential(int sonar_value[0]);
Serial.print("B");
// RIGHT sonar is triggered
/* // turn left
motors_function.Left_Turn();
Serial.print("C");
// differential, turn LEFT
motors_function.Left_Differential(int sonar_value[1]);
Serial.print("C");
// no obstacles near sensors
motors_function.Drive_State(FORWARD); // forward
Serial.print("D");
