#include <Arduino.h>
#ifdef ARDUINO_M5STACK_Core2
#include <M5Core2.h>
#include <driver/i2s.h>
#else
#include <M5Stack.h>
#endif
#include "AudioFileSourceSD.h"
#include "AudioFileSourceID3.h"
#include "AudioGeneratorWAV.h"
#include "AudioOutputI2S.h"
AudioGeneratorWAV *wav;
AudioFileSourceSD *file;
AudioOutputI2S *out;
AudioFileSourceID3 *id3;
bool playing = false;
#define OUTPUT_GAIN 40
//////sound file////
void playWAV (char effect, int volume)
Serial.println("Entered playWAV");
switch (effect)
case 'a':
file = new AudioFileSourceSD("/wav/alarm.wav");
case 'b':
file = new AudioFileSourceSD("/wav/alarmhigh.wav");
case 'c':
file = new AudioFileSourceSD("/wav/alarmlow.wav");
case 'd':
file = new AudioFileSourceSD("/wav/error.wav");
case 'e':
file = new AudioFileSourceSD("/wav/error1.wav");
case 'f':
file = new AudioFileSourceSD("/wav/noread.wav");
case 'g':
file = new AudioFileSourceSD("/wav/noreadings.wav");
case 'h':
file = new AudioFileSourceSD("/wav/normalrange.wav");
case 'i':
file = new AudioFileSourceSD("/wav/warning.wav");
case 'j':
file = new AudioFileSourceSD("/wav/warninghigh.wav");
case 'k':
file = new AudioFileSourceSD("/wav/warninglow.wav");
case 'l':
file = new AudioFileSourceSD("/wav/startup.wav");
case 'm':
case 'n':
file = new AudioFileSourceSD("/wav/update.wav");
////conditions////
//////////////////////CONFIG STATE///////////////////////
void handleAlarmsInfoLine(struct NSinfo *ns) {
struct tm timeinfo;
// calculate sensor time difference
// calculate last alarm time difference
int sensorDifSec=24*60*60; // too much
int alarmDifSec=24*60*60; // too much
int snoozeRemaining = 0;
bool timeOK = getLocalTime(&timeinfo);
if(timeOK){
sensorDifSec=difftime(mktime(&timeinfo), ns->sensTime);
alarmDifSec=difftime(mktime(&timeinfo), lastAlarmTime);
if(timeOK) {
snoozeRemaining = difftime(snoozeUntil, mktime(&timeinfo));
if(snoozeRemaining < 0)
unsigned int sensorDifMin = (sensorDifSec+30)/60;
Serial.print("Alarm time difference = "); Serial.print(alarmDifSec); Serial.println(" sec");
Serial.print("Snooze time remaining = "); Serial.print(snoozeRemaining); Serial.print(" sec, Snooze until "); Serial.println(snoozeUntil);
char tmpStr[10];
M5.Lcd.setTextDatum(TL_DATUM);
if( snoozeRemaining>0 ) {
sprintf(tmpStr, "%i", (snoozeRemaining+59)/60);
if(dispPage<maxPage)
drawIcon(icon_xpos[1], icon_ypos[1], (uint8_t*)clock_icon16x16, TFT_RED);
strcpy(tmpStr, "Snooze");
M5.Lcd.fillRect(icon_xpos[1], icon_ypos[1], 16, 16, BLACK);
M5.Lcd.setTextSize(1);
M5.Lcd.setFreeFont(FSSB12);
// prapare intensity variables for LED strip brightness
int maxint = 255;
maxint *= cfg.LED_strip_brightness;
maxint /= 100;
int lessint = 192;
lessint *= cfg.LED_strip_brightness;
lessint /= 100;
// Serial.print("sensSgv="); Serial.print(sensSgv); Serial.print(", cfg.snd_alarm="); Serial.println(cfg.snd_alarm);
if((ns->sensSgv<=cfg.snd_alarm) && (ns->sensSgv>=0.1)) {
// red alarm state
// M5.Lcd.fillRect(110, 220, 100, 20, TFT_RED);
Serial.println("ALARM LOW");
M5.Lcd.fillRect(0, 220, 320, 20, TFT_RED);
M5.Lcd.setTextColor(TFT_BLACK, TFT_RED);
int stw=M5.Lcd.textWidth(tmpStr);
M5.Lcd.drawString(tmpStr, 159-stw/2, 220, GFXFF);
if( (alarmDifSec>cfg.alarm_repeat*60) && (snoozeRemaining<=0) ) {
sndAlarm();
alarm_low = true;
lastAlarmTime = mktime(&timeinfo);
red();
if((ns->sensSgv<=cfg.snd_warning) && (ns->sensSgv>=0.1)) {
// yellow warning state
// M5.Lcd.fillRect(110, 220, 100, 20, TFT_YELLOW);
Serial.println("WARNING LOW");
M5.Lcd.fillRect(0, 220, 320, 20, TFT_YELLOW);
M5.Lcd.setTextColor(TFT_BLACK, TFT_YELLOW);
sndWarning();
warn_low = true;
yellow();
if( ns->sensSgv>=cfg.snd_alarm_high ) {
// red alarm state
Serial.println("ALARM HIGH");
sndAlarm();
alarm_high = true;
red();}
if( ns->sensSgv>=cfg.snd_warning_high ) {
Serial.println("WARNING HIGH");
sndWarning();
warn_high = true;
yellow();
if( sensorDifMin>=cfg.snd_no_readings ) {
// LONG TIME NO READINGS -> yellow warning state
Serial.println("WARNING NO READINGS");
M5.Lcd.fillRect(0, 220, 320, 20, TFT_CYAN);
M5.Lcd.setTextColor(TFT_BLACK, TFT_CYAN);
no_readings = true;
sndnoreadings();
cyan();
if( strstr(ns->loop_display_label,"Err" )>0 ) {
// LOOP ERROR -> red alarm state
Serial.println("LOOP ERROR");
M5.Lcd.drawString("LOOP", 2, 220, GFXFF);
M5.Lcd.drawString("ERR", 267, 220, GFXFF);
sndAlarm();
if(cfg.LED_strip_mode>=2) {
pixels.fill(pixels.Color(maxint, 0, 0));
pixels.show();
if(cfg.LED_strip_mode==1) {
pixels.clear();
pixels.show();
// normal glycemia state
M5.Lcd.fillRect(0, 220, 320, 20, TFT_BLACK);
M5.Lcd.setTextColor(TFT_LIGHTGREY, TFT_BLACK);
playWAV('h', 3.0);
green();
//volume/100*35
//float volumeGain = (float)OUTPUT_GAIN / (volume * 100.0);
float volumeGain = ((float)volume / 100.0) * 39.0;
Serial.print("volumeGain:");
Serial.println(volumeGain);
id3 = new AudioFileSourceID3(file);
out = new AudioOutputI2S(0, 0); // Output to builtInDAC
out->SetPinout(12, 0, 2);
out->SetOutputModeMono(true);
out->SetGain(volumeGain);
wav = new AudioGeneratorWAV();
wav->begin(id3, out);
void alarm_high1(){
if (alarm_high){
(playWAV('b', 3.0);}
void alarm_low1(){
if (alarm_low){
(playWAV('c', 3.0);
void error1(){
if (error){
(playWAV('e', 3.0);
void no_readings1(){
if (no_readings){
(playWAV('g', 3.0));
void normal_range1(){
if (normal_range){
(playWAV('h', 3.0);
void update1(){
(playWAV('n', 3.0);
Its a quick sketch, but should give you an idea, i have the conditions, the loop for detecting if there is a true statement. and the sound cases
if you indented the code in the IDE before copying (that's done by pressing ctrlT on a PC or cmdT on a Mac) you would see that it's not a suitable code (the loop is not there / missing brackets probably)
I'm not using arduino ide I'm using vscode wasn't sure how to format it. Also yes it's probably not working code I drafted it just as a way to see what I'm doing and specifying the cases
OK - try to post some code that makes sense - we can't do much with that
Will it let me do more than 2000 lines? If so I'll post the whole thing
before you do that, can you try to re-explain in plain English what it is you are struggling with?
Sure, im sorry if I was not clear (ive been up all night and brain is foggy :))
I have a loop going that checks if the conditions are true or false, if true it plays a wav file specified in the case argument. what I am having a problem with is passing (char effect, int volume) to another function. ie the timer function
#include "utility/M5Timer.h"
M5Timer M5timer;
void playwav(){
M5.begin();
M5timer.setTimeout(5000, playwav);
M5timer.run();
What is the purpose of the timer? From your description, I would expect you would start playing as soon as you know which one is required.
the timer callback function does not take any parameters, so you should save the current values for the char effect and volume in global variables that are visible within the callback or implement the business logic into the callback
to repeat the file every 30 minutes while the condition is active. and if the condition changes during that time period it plays the new conditions file.
im going to sound like an idiot, but how should i go about that? i know how to specify global variables. but not store dynamic values.
The timer appears to be more trouble than it is worth. You can just manage your timing using millis.
tried that. can't get it to work right no matter what i do. upon boot of the device it plays the file but never repeats it.
something like this?
char currentCharEffect = '\0'; // none
int currentVolume = 0; // OFF
M5Timer M5timer;
void playCallback() {
playWAV(currentCharEffect, currentVolume);
M5.begin();
M5timer.setTimeout(5000, playCallback);
M5timer.run();
// here some code modifying currentCharEffect and currentVolume
ok, now i am an idiot i should have thought of something like that thank you!
we all started somewhere. Don't feel bad.
if you want to get rid of the timer, you can do this
unsigned long lastTrigger;
const unsigned long period = 5000;
M5.begin();
lastTrigger = millis();
if (millis() - lastTrigger >= period) {
It's marginally dirty though because it requires a couple of globals that would be better avoided. Of course, in a small Arduino program, it doesn't really matter.
I'll try that haven't had luck with Millis yet but we shall see
well, if you need to remember the current values, you'll need variables. with the millis() option they could be static to the loop if this is the only place they are being used, limited gain (and probably best if the business logic was in its own function so I think the globals are OK)
