I am running some test programs on my new wifi shield.
I ran an initial check for it to scan for available networks and that worked fine. It also connects to a network fine. For my next test I tried the Arduino example program “WifiWebClient” and I ran into trouble. There is a part of code that looks like this:
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected to server");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
But my output looks like this:
[q]
Connected to wifi
SSID: twosom2F
IP Address: 192.168.0.9
signal strength (RSSI):-67 dBm
disconnecting from server.
[/q]
So I connected to the server OK, but failed the test :
I put in a println just to confirm and client.connect(server, 80) is indeed not true (0).
Any idea what I should try next to make the example program run?
OK, I admit I haven’t done the firmware upgrade yet, I want to test for basic functionality as much as possible before trying that. The firmware that came installed on the Wifi module is V1.0.0
I will make another post about my questions doing the firmware upgrade.
Any suggestions on how to pass the:
statement?
Thanks,
Drew
