So I have ran into an issue while cleaning up my code and working it into its own library. The issue is related to the callback needed for the ESP8266WebServer .on method.
Here is the error
src\Html.cpp:47:13: warning: 'void _handleIndex()' defined but not used [-Wunused-function]
static void _handleIndex() {
In file included from C:/Users/webmaster/Documents/PlatformIO/Projects/ClockClock/src/ClockClock.ino:1:0:
src\Config.h:12:20: warning: 'stringDays' defined but not used [-Wunused-variable]
static const char *stringDays[] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
Linking .pioenvs\d1_mini\firmware.elf
.pioenvs\d1_mini\src\Html.cpp.o:(.text._ZN4HtmlC2Ev+0x4): undefined reference to `Html::_handleIndex()'
Html.h
#ifndef Html_h
#define Html_h
#include <ESP8266WebServer.h> //Local WebServer used to serve the configuration portal
#include "Arduino.h"
class Html{
public:
Html();
void handleClient();
private:
ESP8266WebServer _server;
char _header[];
char _footer[];
char _index[];
byte _eepromByte;
String _wrapHtml(String body);
static void _handleIndex();
void _redirectToIndex();
#endif
Html.cpp
#include <EEPROM.h>
#include "Config.h"
#include "Html.h"
#include "PadDigit.h"
byte _eepromByte = 0;
char _header[] PROGMEM = R"=====(
<!DOCTYPE html>
<html>
<head>
</head>
<body>
char _footer[] PROGMEM = R"=====(
</body>
</html>
char _index[] PROGMEM = R"=====(
<a href="/add">New Alarm</a>
{alarms}
char _alarm[] PROGMEM = R"=====(
<div>
<a href="/toggle?alarm={index}">{invertedStatus}</a>
<span class="day">{day}</span>
<span class="hour">{hour}</span>:<span class="minute">{minute}</span>
<a href="/delete?alarm={index}">Delete</a>
</div>
String _wrapHtml(String body){
return (String) _header + body + (String) _footer;
void _redirectToIndex() {
_server.sendHeader("Location", String("/"), true);
_server.send ( 302, "text/plain", "");
String html = _index;
// Build the html for the saved alarms
String alarmsHtml = "";
for (unsigned int i = 0; i < ALARM_TOTAL; i++) {
int alarmEnabledIndex = i * 4;
_eepromByte = EEPROM.read(alarmEnabledIndex);
if (_eepromByte != DELETED_STATE) {
String alarmHtml = _alarm;
alarmHtml.replace("{index}", (String) alarmEnabledIndex);
String invertedState = "Disable";
if (_eepromByte == 0) {
invertedState = "Enable";
alarmHtml.replace("{invertedStatus}", invertedState);
alarmHtml.replace("{day}", stringDays[EEPROM.read(alarmEnabledIndex + 1) - 1]); // The day is stored as 1-7 per the Time lib and our day names are of course base 0;
alarmHtml.replace("{hour}", PadDigit::format(EEPROM.read(alarmEnabledIndex + 2)));
alarmHtml.replace("{minute}", PadDigit::format(EEPROM.read(alarmEnabledIndex + 3)));
alarmsHtml += alarmHtml;
html.replace("{alarms}", alarmsHtml);
_server.send(200, "text/html", _wrapHtml(html));
Html::Html(){
ESP8266WebServer _server(80);
_server.on("/", _handleIndex);
//_server.on("/add", handleForm);
//_server.on("/save", handleSave);
//_server.on("/delete", handleDelete);
//_server.on("/toggle", handleToggle);
_server.begin();
void Html::handleClient(){
_server.handleClient();
void handleForm() {
String html = htmlForm;
server.send(200, "text/html", html);
void handleSave() {
for (int i = 0; i < ALARM_TOTAL; i++) {
_eepromByte = EEPROM.read(alarmEnabledIndex); // I am keeping the enabled byte at the head of each "page". A page beeing four bytes consisting of enabled, day, hour, minute
if (_eepromByte == DELETED_STATE) { // Find the first available slot
// Do save
EEPROM.write(alarmEnabledIndex, 1);
EEPROM.write(alarmEnabledIndex + 1, server.arg("day").toInt());
EEPROM.write(alarmEnabledIndex + 2, server.arg("hour").toInt());
EEPROM.write(alarmEnabledIndex + 3, server.arg("minute").toInt());
EEPROM.commit();
_redirectToIndex();
server.send(200, "text/html", htmlErrorLimit); // Send out the error page if we have hit the max alarms
void handleDelete() {
if (server.hasArg("alarm")) {
EEPROM.write(server.arg("alarm").toInt(), 2);
EEPROM.commit();
_redirectToIndex();
void handleToggle() {
int i = server.arg("alarm").toInt();
eepromByte = EEPROM.read(i);
EEPROM.write(i, 1);
else {
EEPROM.write(i, 0);
EEPROM.commit();
_redirectToIndex();
inside my loop I am calling
htmlLib.handleClient();
