I am attempting to send a short message.
I get nothing seen at the receiver side.
I am using the ASK RadioHead library; I have a copy of the example. The only changes I have made were added to aid debugging.
The transmitter and receiver are tuned to each other.
- I cleared the receiver (8 presses)
- I set the receiver to learn (one press)
- I sent a signal with the transmitter, and the receiver seemed to respond.
i.e. removing and adding power to the transmitter lights the receiver.
When powered, both transmitter and receiver have a constant light; the transmitter has a slight flicker corresponding to the code delay.
I have attempted to connect the DATA line to the other data pins on both the transmitter and the receiver with no perceived changes.
I have replaced both the transmitter and the receiver.
Oddly, removing the power from the transmitter so that there is only GND & DATA connected, the light on the transmitter flashes (as it might have expected when powered) with the delay time in the code.
Transmitter
Arduino Micro connected to a TX118S
Connections
TX118S | Arduino |
- | GND |
+ | 5v |
1 | 12 |
Images so you can be sure I have my head straight about which pin is which
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
RH_ASK driver; // txPin = 12
Serial.begin(9600); // Debugging only
if (!driver.init())
Serial.println("init failed");
const char *msg = "Hello World!";
driver.send((uint8_t *)msg, strlen(msg));
driver.waitPacketSent();
Serial.println(msg);
Receiver
Connections
RX480E | Arduino |
GND | GND |
+V | 3.3v |
D0 | 11 |
#include <RH_ASK.h>
RH_ASK driver; // rxPin = 11
driver.init();
uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
uint8_t buflen = sizeof(buf);
if (driver.recv(buf, &buflen)) // Non-blocking
// Message with a good checksum received, dump it.
Serial.print("Message: ");
Serial.println((char*)buf);
Serial.println("No Message");
The anntena are both 17cm.
My apologies in advance
- If this is something obvious that I have missed - this is my first project ever.
- I am posting in the wrong way/place - this is my first post.
The closest post I have seen to this is this one. I added the antennas after reading the post.
Keith
