Passing data from PC to Ardiuno / CNC shield
I have a CNC shield setup with 3 motors
I want to be able to pass a byte value (Position) from a text file on my PC to Ariduno while its running. It will wait until it recieves a value != 0 and if statements will determine how far the motors move, but im unsure on how to achieve this. Also might send a "at home position" signal to the PC so it knows to send the next byte value.
There is a large portion of the code im using ommited here
void step (boolean dir, byte dirPin, byte stepperPin, int steps) {
  digitalWrite (dirPin, dir);
  delay (50);
  for (int i = 0; i < steps; i++) {
    digitalWrite (stepperPin, HIGH);
    delayMicroseconds (800);
    digitalWrite (stepperPin, LOW);
void loop () {
byte Position = 0;
//Wait for obtained data here from PC and change Position value
if (Position != 0){
  if (Position == 1){step (true, X_DIR, X_STP, 100); step (true, Y_DIR, Y_STP, 0);}
  if (Position == 10){step (true, X_DIR, X_STP, 400); step (true, Y_DIR, Y_STP, 200);}
  if (Position == 23){step (true, X_DIR, X_STP, 500); step (true, Y_DIR, Y_STP, 600);}
//ect...
you could do something like this
const byte X_DIR = 13;
const byte X_STP = 12;
const byte Y_DIR = 11;
const byte Y_STP = 10;
    delay (50);
void loop ()
    byte position = 0;
    // check for serial input
    if (Serial.available ())  {
        char buf [80];
        int n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        position = atoi (buf);
    switch (position) {
    case 1:
   case 10:
    case 20:
void
setup ()
    Serial.begin (9600);
    pinMode ( X_DIR, OUTPUT);
    pinMode ( X_STP, OUTPUT);
    pinMode ( Y_DIR, OUTPUT);
    pinMode ( Y_STP, OUTPUT);
or something like this
void step (
    int  nStep, byte dirPin, byte stepPin)
    digitalWrite (dirPin, 0 > nStep ? false : true);
    delay (50);
    for (int i = 0; i < abs(nStep); i++) {
        digitalWrite      (stepPin, HIGH);
        delay(80);
        digitalWrite      (stepPin, LOW);
        delay(80);
void
stepXy (
    int  xStep,
    int  yStep )
    step (xStep, X_DIR, X_STP);
    step (yStep, Y_DIR, Y_STP);
void loop ()
    int xStep;
    int yStep;
        char buf [80];
        buf [n] = '\0';
        sscanf (buf, "%d, %d", &xStep, &yStep);
        stepXy (xStep, yStep);
void
setup ()
