Hello gurus/-ettes,
I am satisfying my appetite for tinkering with a multicolor LED control system.
I have three potentiometers mapped to r, g and b, so I can get any color out of the LED.
To add the somersault points, I included three four digit, 7 segment LEDs. Each will show one of the rgb component values of the LED. I got it to work with one such display, no problem, but adding the other two has me baffled.
As I have thought of it, I have an array of 12 elements. This reads something like 025500000000 when the LED is all red, to 025502550255 for all white, etc. My idea was that if I pass that array to the shift registers, it would be read and displayed correctly.
The structure that does it for one value is
void makeArray(){
redDig1 = int(valR/100);
redDig2 = int((valR/10) % 10);
redDig3 = int(valR-100*redDig1-10*redDig2);
greenDig1 = int(valG/100);
greenDig2 = int((valG/10) % 10);
greenDig3 = int(valG-100*greenDig1-10*greenDig2);
blueDig1 = int(valB/100);
blueDig2 = int((valB/10) % 10);
blueDig3 = int(valB-100*blueDig1-10*blueDig2);
myArray[0] = 0xc0; //first digit of first LED unit is 0
myArray[1] = num[redDig1];
myArray[2] = num[redDig2];
myArray[3] = num[redDig3];
myArray[4] = 0xc0; //first digit of second LED unit is 0
myArray[5] = num[greenDig1];
myArray[6] = num[greenDig2];
myArray[7] = num[greenDig3];
void showArray(){
for (int i = 0; i < 4; i++) {
// Select a single 7-segment display
chooseCommon(i);
// Send data to 74HC595
writeData(myArray[i]);
delay(6);
// Clear the display content
//writeData(0xff);
void chooseCommon(byte com) {
// Close all single 7-segment display
digitalWrite(comPin[i], LOW);
// Open the selected single 7-segment display
digitalWrite(comPin[com], HIGH);
void writeData(int value) {
// Make latchPin output low level
digitalWrite(latchPin, LOW);
// Send serial data to 74HC595
shiftOut(dataPin, clockPin, LSBFIRST, value);
// Make latchPin output high level, then 74HC595 will update the data to parallel output
digitalWrite(latchPin, HIGH);
But when I try to expand to the second shift register by upping the loop to eight elements (the i loop), it doesn’t do as I expected, so I must be doing something horribly wrong.
So, in essence my question boils down to how to pass three different values to three daisy chained shift registers? I am attaching the full file here so those interested can have a peek.
I am sorry if this is irritatingly low-level for you but it’s keeping me awake at night almost as much as Boris Johnson is.
Arduino_Ultimate_RGB_LED.ino (4.51 KB)
