I am developing a program to control the locks and latches on a number of vent doors. It's going well so far and I have completed the latch portion and am about to start on the locks.
I wrote init functions to initialize the I/O pins. The buttonInit() function will work for both locks and latches, but latchInit() as written will only work for latches as it takes a latch object as an input parameter. Since a lockInit() function would be identical it would be nice if I could have one function that could initialize the output pins for either a latch or lock object.
So my question is how do I get a function to accept either a latch or a (future)lock object as an input parameter?
// ================= GLOBAL VARIABLES ================
const uint8_t LATCH1_BUTTON_PIN = 12;
const uint8_t LATCH1_OUTPUT_PIN = 13;
const uint8_t LATCH_DISABLE_SENSOR_PIN = 11;
enum ButtonStates
NO_CHANGE, // No change in event status
PRESS, // Press event begins
QUICK_PRESS, // Event has ended as a quick press
LONG_PRESS // Event has ended as a long press
// ================= STRUCTS ================
struct Button
ButtonStates buttonState;
uint8_t ButtonPin;
uint8_t ButtonBuffer = 0;
bool IsButtonPressed = false;
uint32_t ButtonTimerStart = 0;
uint32_t ButtonTimerInterval = 10;
uint8_t PressIntervals = 1;
uint8_t ReleaseIntervals = 4;
uint32_t PressStartTime = 0;
static const uint32_t PressThresholdTime = 350;
bool LongPressDetected = false;
struct Latch
uint8_t LatchPin;
bool LatchActive = false;
uint32_t LatchStartTime = 0;
static const uint32_t LATCH_ACTIVATION_INTERVAL = 500;
static const uint32_t LATCH_REACTIVATION_DELAY = 250;
// ================= OBJECTS ================
Button Latch1Input;
Latch Latch1Output;
// SETUP FUNCTIONS
pinMode (LATCH_DISABLE_SENSOR_PIN, INPUT_PULLUP);
buttonInit(Latch1Input, LATCH1_BUTTON_PIN);
latchInit (Latch1Output, LATCH1_OUTPUT_PIN);
void buttonInit (Button &button, const uint8_t &BUTTON_PIN)
button.ButtonPin = BUTTON_PIN;
pinMode (button.ButtonPin, INPUT_PULLUP);
void latchInit (Latch &latch, const uint8_t &LATCH_PIN)/* */
latch.LatchPin = LATCH_PIN;
pinMode (latch.LatchPin, OUTPUT);
// Loop
updateLatch(Latch1Output, Latch1Input);
// updateLatch
void updateLatch (Latch &latch, Button &button)
uint32_t currentTime = millis();
if (latch.LatchActive)
if (currentTime - latch.LatchStartTime >= latch.LATCH_ACTIVATION_INTERVAL)
digitalWrite(latch.LatchPin, LOW);
if (currentTime - latch.LatchStartTime >= (latch.LATCH_ACTIVATION_INTERVAL + latch.LATCH_REACTIVATION_DELAY))
latch.LatchActive = false;
else if (!digitalRead(LATCH_DISABLE_SENSOR_PIN))
if (updateButton(button, currentTime) == PRESS)
digitalWrite(latch.LatchPin, HIGH);
latch.LatchStartTime = currentTime;
latch.LatchActive = true;
// updateButton
ButtonStates updateButton (Button &button, const uint32_t &CURRENT_TIME)
// ============== set default return value ==============
button.buttonState = NO_CHANGE;
if (CURRENT_TIME - button.ButtonTimerStart >= button.ButtonTimerInterval)
// ============== reset timer ==============
button.ButtonTimerStart += button.ButtonTimerInterval;
// ============== limit intervals to max allowed by the buffer size ==============
// ============== byte sized buffer allows max 7 intervals, int allows 15 ==============
//const uint8_t MAX_INTERVALS = 7;
const uint8_t MAX_INTERVALS = (sizeof(button.ButtonBuffer) <<3) -1;
if (button.PressIntervals > MAX_INTERVALS)
button.PressIntervals = MAX_INTERVALS;
if (button.ReleaseIntervals > MAX_INTERVALS)
button.ReleaseIntervals = MAX_INTERVALS;
// ============== shift oldest read out and add new read ==============
button.ButtonBuffer = (button.ButtonBuffer << 1) + (!digitalRead (button.ButtonPin));
if (button.IsButtonPressed == false)
uint8_t pressDebounceMask = (1 << (button.PressIntervals + 1)) - 1;
if (button.ButtonBuffer & pressDebounceMask)
button.IsButtonPressed = true;
button.buttonState = PRESS;
button.PressStartTime = CURRENT_TIME;
else // button.IsButtonPressed == true
uint8_t releaseDebounceMask = (MAX_INTERVALS - button.ReleaseIntervals); // Number of reads to ignore
if (CURRENT_TIME - button.PressStartTime >= button.PressThresholdTime)
if (!button.LongPressDetected)
button.LongPressDetected = true;
if (button.ButtonBuffer << releaseDebounceMask)
button.IsButtonPressed = false;
if (button.LongPressDetected)
button.buttonState = LONG_PRESS;
button.LongPressDetected = false;
button.buttonState = QUICK_PRESS;
return button.buttonState;
