I am wanting to printout the current processor time on a webpage that shows other queried data from the ESP32 processor. The issue is
I cannot define the integers hour, min, and sec outside the void printLocalTime() without generating a compiler error. But I need to reference those integers in a manner similar to:
void printLocalTime() { // this function monitors current time of day to initiate
// pump counter reset at midnight
struct tm timeinfo;
if (!getLocalTime(&timeinfo)) {
Serial.println("Failed to obtain time");
return;
// Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S zone %Z %z ");
int hour = timeinfo.tm_hour;
int min = timeinfo.tm_min;
int sec = timeinfo.tm_sec;
if (hour == hour_trigger && min == min_trigger && sec == sec_trigger) {
Serial.println("Reset counters...");
counter_reset = true;
If there is a much more efficient straightforward way to add a processor's current time to a webpage I am all ears.
thanks...
Ok, I moved the integer definitions hour, min, sec out of void printLocalTime() and placed them in my constants.h file. After reading the entire error message I realized I had used "hour" in a previous declaration so I changed integers descriptors to time_hour, time_min, & time_sec to avoid that conflict. But I am still getting an error about 'timeinfo' was not declared in this scope:
WARNING: library StackString claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
In file included from C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8L\Pump_House_Monitor_ver8L.ino:19:
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8L\constants.h:61:17: error: 'timeinfo' was not declared in this scope
boolean counter_reset = false;
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8L\constants.h:61:17: note: suggested alternative: 'time'
time
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8L\constants.h:62:17: error: 'timeinfo' was not declared in this scope
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8L\constants.h:62:17: note: suggested alternative: 'time_min'
time_min
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8L\constants.h:63:17: error: 'timeinfo' was not declared in this scope
boolean bldg_alm_ON = false;
C:\Users\Ed\IDE 2.0 Sketches-Libraries\Pump_House_Monitor_ver8L\constants.h:63:17: note: suggested alternative: 'time_sec'
time_sec
Multiple libraries were found for "WiFi.h"
Used: C:\Users\Ed\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9\libraries\WiFi
Not used: C:\Users\Ed\IDE 2.0 Sketches-Libraries\libraries\WiFiNINA
exit status 1
Compilation error: 'timeinfo' was not declared in this scope
added constants.h segment containing timeinfo :
int hour_trigger = 23; // hour to reset pump counters to zero
int min_trigger = 59; // minute (23 : 59 : 59)
int sec_trigger = 59; // second HR MIN SEC
int time_hour = timeinfo.tm_hour; // tm structure element "hour" from time.h
int time_min = timeinfo.tm_min; // "minute" " "
int time_sec = timeinfo.tm_sec; // "second"
int current_pump_cycle_min = 10; // Example value, replace with your actual variable
client.print("Current Pump Cycle [minutes] = ");
client.println(current_pump_cycle_min);
Replace current_pump_cycle_min with your actual variable representing the pump cycle duration in minutes. This code will print the message and the value to the client.
