Passing Methods/Functions in Parameter
I’m clearly doing something wrong here, but it all looks correct to me. Any ideas? For the most part I’ve removed everything except what is causing the error. It’s a class that handles menu navigation on an LCD.
class MenuItem
public:
  typedef void (*function)();
  MenuItem *subMenus;
  function action;
  function elevate;
  MenuItem()
    subMenus = NULL;
    action = NULL;
    elevate = NULL;
  void elevateToSelf()
    //do stuff here.
  void call(function menuItemElevate)
    elevate = menuItemElevate;
    if(action != NULL)
      action();
    else if(subMenus != NULL)
      subMenus[0].call(elevateToSelf);
In file included from MenuItem.cpp:4:
/test.h: In member function 'void MenuItem::call(void (*)())':
test.h:29: error: no matching function for call to 'MenuItem::call(<unresolved overloaded function type>)'
/test.h:20: note: candidates are: void MenuItem::call(void (*)())
Thanks,
Stauffski
Post complete code.
You're sure you don't need "*" on this line "action();"?
Yes, I’m positive. Here’s an even more simplified version. Sorry for any confusion.
class MenuItem
public:
  MenuItem *subMenus;
  function action;
  function elevate;
  MenuItem()
    subMenus = NULL;
    action = NULL;
    elevate = NULL;
    //do stuff here.
  void setElevation(function menuItemElevate)
  void test()
    subMenus[0].setElevation(elevateToSelf);
/test.h: In member function 'void MenuItem::test()':
test.h:25: error: no matching function for call to 'MenuItem::setElevation(<unresolved overloaded function type>)'
/test.h:20: note: candidates are: void MenuItem::setElevation(void (*)())
You are declaring 'function' as a regular pointer-to-function type, but you are trying to pass it a pointer-to-member-function instead. Google for "pointer to member" and you will find some explanations, e.g. http://publib.boulder.ibm.com/infocenter/comphelp/v8v101/index.jsp?topic=%2Fcom.ibm.xlcpp8a.doc%2Flanguage%2Fref%2Fcplr034.htm.
