Passing multipul arrays
I am trying to get this function right.
I have an set of array's each with 33 numbers. I want pass a different of amount of arrays to a function to process them.
this is what i am doing now:
void actionscript2s(int arrayH[], int array1[],int array2[], int repeat){
  int i = 0;
  int temp = 0;
   for (int x = 0;  x < repeat; x++){
    for (i = 0; i < servocount; i++)
        Serial.print(" #");
        Serial.print(i);
        Serial.print(" P");
        temp = (array1[i]+arrayH[i]);
        Serial.print(temp);
        finishoutput((array1[servocount]));
        delay((array1[servocount]));
        Serial.print(" #");
        Serial.print(i);
        Serial.print(" P");
        temp = (array2[i]+arrayH[i]);
        Serial.print(temp);
its for my octobot. I want to save some space and rewrite to be able to pass any number of arrays to and it have it process them x times
any help would be awesome.
If you understand pointers, you can pass a pointer to an array of arrays:
loop()
      int *arrayTemp[2];
                // arraytemp holds the arrays to work with, in this case array1 and array2
      arrayTemp[0] = array1;
      arrayTemp[1] = array2;
                // do the work with the arrays here - we have two of them, so pass 2.
      actionscript2s(arrayTemp, 2);
      printf("done");
void actionscript2s(int *arr[], int numArrays)
      for(int i=0;i<numArrays;i++)
                      // the array is arr[i].
                     // here we can walk the members of arr[i].
                     for(int am=0;am<=15;am++)
                          Serial.print((arr[i])[ii]);
that will work for me. now if i can get the arduino IDE to stop crashing when i try to compile my Inverse Kinematics port i am good.
