Passing Object function as callback
Hi guys,
im working with my first classes and now i want to pass a function as callback but i dont get it to work. The Code:
NETSerial.h
class NETSerial {
private:
    void (*iCallback)(char[]);
    void processIncoming();
public:
    NETSerial();
    void onReceive(void (*callback)(char[]));
NETSerial.cpp
void NETSerial::onReceive(void (*callback)(char[]))
	iCallback = callback;
void NETSerial::processIncoming()
	// Callback
	iCallback(receivedData);
NETController.h
class NETController {
private:
public:
    NETController();
    void onSerialRec(char msg[]);
NETController.cpp
void NETController::onSerialRec(char msg[]) {
	Serial.print("Conroller callback=>");;
	Serial.println(msg);
Programm.ino
// Serial
NETSerial USBSerial = NETSerial();
// Controller
NETController Controller = NETController();
     // THIS WORKS
    USBSerial.onReceive(&test);
   // THAT DONT WORK
   USBSerial.onReceive(&Controller.onSerialRec);
void loop(){
void test(char msg[]) {
    Serial.print("Callback msg=>");
    Controller.onSerialRec(msg);
As you can see i can pass a function declared in the main ino file like my "test" function. But i cant pass a function from an object of my NETController class.
The original classes are much bigger but i stripped that all out. Hope my code is ok to describe my problem.
Best regards,
Raphael
pass the object
If you know which method to call beforehand, then what @Juraj suggested seems to be the way to go.
Otherwise, you might want to have a look at pointers to member functions. For example,
class C {
public:
  void print() {
    Serial.println("Hi.");
void test(C& obj, void (C::*f)()) {
 (obj.*f)();
  C c;
  test(c, &C::print);  // Prints "Hi.".
