Hi arduino'ers, Master Arduino...
Could you please help me , i'm very new in arduino, i'm facing problem to passing the rfid uid to textfield in php via network,i'm using uno,mfrc522 and Ethernet shield W5100, for now I able to send and save rfid uid to MySQL database, but in another reason I want to send rfid uid to text field in php before I save to the MySQL database. my code is :
Arduino code:
#include <SPI.h>
#include <MFRC522.h>
#include <Ethernet.h>
#define SS_PIN 7
#define RST_PIN 6
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(192,168,1,201); //
IPAddress ip(192,168,1,202); //
EthernetServer svr(80);
EthernetClient client; //
String readString;
int first=0;
int counter=0;
String uID;
svr.begin(); //
Serial.begin(9600); //
Serial.println("Server/Client test");
Serial.println("Sending data RFID Test");
// disable SD SPI
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
// disable w5100 SPI
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
SPI.begin(); //
mfrc522.PCD_Init(); //
Ethernet.begin(mac, ip); //
// Local IP address:
Serial.print("My IP address: ");
for (byte thisByte = 0; thisByte < 4; thisByte++) {
// cetak IP address:
Serial.print(Ethernet.localIP()[thisByte], DEC);
Serial.print(".");
Serial.println("connecting...");
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
int val1=(mfrc522.uid.uidByte[0]);
int val2=(mfrc522.uid.uidByte[1]);
int val3=(mfrc522.uid.uidByte[2]);
int val4=(mfrc522.uid.uidByte[3]);
String valA=String(val1);
String valB=String(val2);
String valC=String(val3);
String valD=String(val4);
uID=valA+valB+valC+valD;
Serial.print(uID);
counter=counter+1;
Serial.print(counter);
// Halt PICC
mfrc522.PICC_HaltA();
// Stop encryption on PCD
mfrc522.PCD_StopCrypto1();
if (counter>first)
{//delay ifs
// enable w5100 SPI
//Start as Server Now
EthernetClient client= svr.available();
if(client){
while (client.connected()){
if (client.available()){
char c = client.read();
if (client.connect(server, 80)) { //start of IF
Serial.println("connected");
// Make a HTTP request:
client.print("GET /sys/new.php?scnId="); //dont make these println
client.print(uID); //dont make these println
client.println("HTTP/1.1");
client.println("Host: 192.168.1.201");
client.println("User-Agent: Arduino");
client.println("Accept: text/html");
client.println(server);
client.println("Content-Type: application/x-www-form-urlencoded");
client.println("Connection: close");
client.println();
Serial.print("SENT");
first++;
Serial.print(first);
while(client.connected()){
while(client.available()){
Serial.write(c);
client.stop();
} //end OF IF
}//delay ifs
what should I add into the Arduino code , so that to be display on textfield in PHP. please help me,Thank you.
