Passing Serial data over I2C to another Arduino
Here I have an arduino mega (Master) and an Uno (Slave). Both of them are connected to my laptop over USB ports. I would like to turn on the LED on arduino Uno when I write the “ON” on the adruino mega’s Serial monitor which I have on my laptop’s screen. unfortunately it doesn’t work. :frowning:
I would be grateful if you let me know how can I solve this problem. :confused:
here’s the Master code which is connected to both I2C and serial ports. :smiley:
#include <Wire.h>
String Input_data_String = "";
char   Input_data_string[5];
const int ledPin =13;
     Wire.begin();
     while (!Serial) {
 delay(10);
void serialEvent() {
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    Input_data_String += inChar;
    if (Contains(Input_data_String ,"Read")){
      Input_data_String.toCharArray(Input_data_string,5);
      //Serial.println ("Message from Arduino");
      Wire.beginTransmission(2);           // transmit to device #2
      Wire.write(Input_data_string);       // sends String
      Wire.endTransmission();              // stop transmitting
      Input_data_String ="";}
    if (Contains(Input_data_String ,"ON")){
     if (Contains(Input_data_String ,"OFF")){
 bool Contains( String s, String search) {
    int max = s.length() - search.length();
    for (int i=0; i<= max; i++)
    if (s.substring(i) == search) return true;  // or i
    return false;  //or -1
And here’s my slave code which is connected via I2C to the master.
#include <Wire.h>
String Data = "";
char data[5];
  Wire.begin(2);
  Wire.onReceive(receiveEvent);
  pinMode(13,OUTPUT);
  digitalWrite(13,LOW);
  delay(100);
void receiveEvent(int howMany) {
  while( Wire.available()){
    Data += (char)Wire.read();
if (Data == "ON"){
      digitalWrite(13, HIGH);
      Data="";}
if (Data == "OFF"){
      digitalWrite(13, LOW);
      Data="";}
Your code seems to be confused: if you just want to send data from the Master to the Slave, look at the Wire.h example:
Master:
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
  Wire.beginTransmission(8); // transmit to device #8
  Wire.write("x is ");        // sends five bytes
  Wire.write(x);              // sends one byte
  x++;
Slave:
#include <Wire.h>
  Wire.begin(8);                // join i2c bus with address #8
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
  while (1 < Wire.available()) // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print(c);         // print the character
  int x = Wire.read();    // receive byte as an integer
  Serial.println(x);         // print the integer
If you want to send and receive String:
Master
#include <Wire.h>
#define I2CAddress 9
String text;
void getText(){
  if(Serial.available()) // check if we send a message
    while(Serial.available())
      char c = Serial.read(); // read the next character.
      text += c;
      delay(10);
void sendText() {
  Wire.beginTransmission(I2CAddress); // transmit to device #9
  for(int i=0; i<(text.length()); i++){
    Wire.write(text[i]);
  Serial.println("Master here");
  // Start the I2C Bus as Master
  Wire.begin();
  text = "";
  while(text.length() == 0) { // Until we send text in the serial monitor
    getText();
  if(text.length() > 0) {
     Serial.print("Send: " + text);
     sendText();
Slave:
#include <Wire.h>
#define ledPin 13
void receiveString(int bytes) {
  String text = "";
  while (Wire.available()) {
    char c = Wire.read(); // receive a byte as character
    text += c;
  Serial.print("Printing: ");
  Serial.println(text);
  manageLed(text);
void manageLed(String cmd) {
  if(cmd == "ON")
    digitalWrite(ledPin,HIGH);
  else if(cmd == "OFF")
    digitalWrite(ledPin,LOW);
    Serial.println("Unknown command: " + cmd);
  Serial.println("Slave here");
  // Start the I2C Bus as Slave on address 9
  Wire.begin(I2CAddress);
   // Attach a function to trigger when something is received.
  Wire.onReceive(receiveString);
  // LED
  pinMode(ledPin,OUTPUT);
  delay(10);
PS: I didn’t try the code on 2 arduinos
