"homeassistant/sensor/blah" is a char*
So, if I wanted to use dynamic values on this, if it were a string you'd do:
int myval=5;
mqtt_client.publish("homeassistant/sensor/blah" + String(myval), "parameter_value");
As it's a char you'd ideally need to use strcpy to create the char array prior to using it, like this:
int myval=5;
char* publish_start = "homeassistant/sensor/blah";
char* publish_entry;
strcpy(publish_entry, publish_start);
mqtt_client.publish(publish_entry, "parameter_value");
However this seems really excessive and wasteful as for example if I was to publish 10 then I'd need 20 char values defined, stcpy each one then publish them. Is that right or am I missing something here too?
that would fail because you have no memory allocated to strcpy the result into
if you want to build "homeassistant/sensor/blah5" or "homeassistant/sensor/blah6" then you need to allocate a large enough buffer to hold the cString and build it up using cString functions ( see stdlib.h and string.h)
if you use the String class (not really recommended, it comes with... strings attached) you could build the right String into myString and call the mqtt_client.publish() function with myString.c_str() as a first parameter.
Strings are the safer way to go, from a coding point of view. It this is an ESP32 you are already using a lot of Strings in the web libraries, so
// global constant
const char urlBase[ ] = "homeassistant/sensor/blah";
int myval = 5;
{ // this block cleans up String url after it is finished with to void leaving it in memory for the whole loop()
String url = urlBase;
url += myval;
mqtt_client.publish(url.c_str(), "parameter_value");
As for the MQTT clients, Adafruit's does not seem to use Strings while Arduino's (beta) does.
Some great bits of info here, thank you all.
I've been trying to avoid Strings, because, well, strings! (But yes, drmpf it's esp8266 so yeah Strings everywhere!)
I went with the method J-M-L and blh64 suggested, creating the buffer with the size I needed and just re-using the char array each time, changing it with my values then publishing.
Which you use abundantly as well as all those functions invented decades ago in your library.
There is a shared view by many here that Understanding cStrings and their pitfalls is a critical knowledge to gain if you program in C or C++ esp. for small microcontrollers.
Checking against buffer overflow, understanding the stack and heap and what happens in dynamic memory allocation will go a long way in helping anyone build better code.
Once this is acquired, if the developer chooses so, they can go to canned solutions offering more bells and whistles at the cost of more memory and CPU time and that won’t even protect them as they will still need to test if the instruction has worked anyway (after the fact rather than before the fact).
