Passing structs to functions
I'm having an error when trying to pass a struct to different functions. I followed this guide (specifically the procedure outlined in #8) Passing struct to function (again) - Syntax & Programs - Arduino Forum and am still having issues.
Here is my 'rtc.h'.
#ifndef rtc_h
#define rtc_h
typedef struct{
    int seconds_ones;
    int seconds_tens;
    int minutes_ones;
    int minutes_tens;
    int hours_ones;
    int hours_tens;
    int date_ones;
    int date_tens;
    int month_ones;
    int month_tens;
    int year_ones;
    int year_tens;
} RTC_STRUCT;
#endif
Here is my main application.
#define rtc_address B1101000
#define rtc_seconds 0x00
#define rtc_minutes      0x01
#define rtc_hours        0x02
#define rtc_day          0x03
#define rtc_date         0x04
#define rtc_month        0x05
#define rtc_year         0x06
#define rtc_control      0x0E
#define rtc_status       0x0F
#define rtc_trickle      0x10     // all defines above are register addresses
#define rtc_trickle_val  0xA6     //no diode, 2k ohm
#define set_seconds_ones 0
#define set_seconds_tens 0
#define set_minutes_ones 0
#define set_minutes_tens 0
#define set_hours_ones   0
#define set_hours_tens   0
#define set_date_ones    2
#define set_date_tens    2
#define set_month_ones   4
#define set_month_tens   0
#define set_year_ones    7
#define set_year_tens    1
//all defines above are for initial setting of RTC time
#include <Wire.h>
#include "rtc.h"
RTC_STRUCT rtc = {set_seconds_ones, set_seconds_tens, set_minutes_ones, set_minutes_tens,
  set_hours_ones, set_hours_tens, set_date_ones, set_date_tens, set_month_ones, set_month_tens,
  set_year_ones, set_year_tens};
  Wire.begin(); //I2C initialization
void loop(){
  i2c_read( &rtc );
  Serial.println("----------");
  Serial.print("Seconds:");
  Serial.print(rtc.seconds_ones);
  Serial.println(rtc.seconds_tens);
void i2c_read( rtc* r){
  byte i2c_read_buffer[17];
  Wire.beginTransmission(rtc_address);          //send rtc address
  Wire.write(rtc_seconds);                      //start position of read
  int n = Wire.requestFrom(rtc_address, 17);    //request only one byte
  if(Wire.available ()<= 17){
    for (int i = 0; i < n; i++){
      i2c_read_buffer[i] = Wire.read();         //read that byte
  Wire.endTransmission();                       //end read
  for (int i = 0; i < n; i++){                  //fill the struct
    if(i = 0)
      r -> seconds_ones = i2c_read_buffer[i] & B00001111;
      r -> seconds_tens = i2c_read_buffer[i] >> 4;
    else if(i = 1)
      r -> minutes_ones = i2c_read_buffer[i] & B00001111;
      r -> minutes_tens = i2c_read_buffer[i] >> 4;
    else if(i = 2)
      r -> hours_ones = i2c_read_buffer[i] & B00001111;
      r -> hours_tens = i2c_read_buffer[i] >> 4;
    else if(i = 4)
      r -> date_ones = i2c_read_buffer[i] & B00001111;
      r -> date_tens = i2c_read_buffer[i] >> 4;
    else if(i = 5)
      r -> month_ones = i2c_read_buffer[i] & B00001111;
      r -> month_tens = i2c_read_buffer[i] >> 4;
    else if(i = 6)
When I try to compile this I get the following error:
rtc_1:76: error: 'r' was not declared in this scope
exit status 1
variable or field 'i2c_read' declared void
I'm a little confused about this because I thought that r would have inherited the datatype RTC_STRUCT from the rtc struct that is getting passed to it. As far as I can tell this is exactly what they're doing in the example I gave that supposedly works.
Any help is appreciated. Thank you.
void i2c_read( RTC_STRUCT * r){
    if(i = 0)
Oops.
Thanks for the help!
And thank you for catching the if( i=0) as well!
You are welcome.
In case you're wondering why CB made the correction he did, it's because you need to specify the type of the argument in the list, but you were putting a variable name in that spot.
