passing time value from PHP to arduino [Solved]
OK, I have been banging my head over this for the last day and getting close but no good.
I have arduino with ethernet shield and it is reading from a php webpage that simply echo time();
on the arduino side, I read this with char instring.
when i print instring I get the correct value
instring = 1327202474 which is a char array
and when i convert char to time_ t type using time_t timeValue = atoi(inString) timevalue when set to time_t results in 4294934968 and time is like feb 6 2106.
i am setting the arduino clock with ** setTime(timevalue);**
I would paste the code but it has been chopped up pretty badly due to cut and paste from examples and debuggin. Hopefully this is enough info to help a beginner…
Thanks
any idea what is going on?
EDIT : Somehow could not get atoi(), so reverted to the example code for time serial using
for(int i=0; i < TIME_MSG_LEN -1; i++){
        char c = inString[i];
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      Serial.print(pctime);
      setTime(pctime);   // Sync Arduino clock to the time received on the serial port
Couldn't get it? Or couldn't get it to work?
If it is latter, and this is true:
What size shoehorn do you have available to stuff that value into an int?
Do you know what the i on atoi() means?
