Passing typedef structs fails?
Is it possible to pass typedef structs as function parameters? I get this error when I try to do so:
sketch_nov19a:3: error: variable or field 'showRGB' declared void
sketch_nov19a:3: error: 'RGB' was not declared in this scope
sketch_nov19a:3: error: 'rgb' was not declared in this scope
Here is my test code:
// A simple struct
typedef struct
  unsigned char r;
  unsigned char g;
  unsigned char b;
} RGB;
// Function forward declaration
void showRGB(RGB* rgb);
// Obligatory setup
  RGB rgb;
  rgb.r = 127;
  rgb.g = 63;
  rgb.b = 255;
  showRGB(&rgb);
// Obligatory loop
// Function to test struct parameter passing
I am using Mac OS X 10.6.8. The same code compiles using CC.
Ah, the IDE is “helping” you here by modifying your source for you.
This makes it compile:
Take the typedef (these lines) and put them into another file. To do this make a new tab in the IDE (button on top RH corner). I used foo.h, containing:
// A simple struct
typedef struct
  unsigned char r;
  unsigned char g;
  unsigned char b;
} RGB;
Now your main code reads:
#include "foo.h"
// Obligatory setup
  RGB rgb;
  rgb.r = 127;
  rgb.g = 63;
  rgb.b = 255;
  showRGB(&rgb);
// Obligatory loop
And, tada! It compiles.
Wow! Sure enough! Splitting the typedef out into a header file works great. That's sort of strange. I am using the Arduino IDE by the way. Thank you for the help!
