I am hosting a web server from my Arduino uno and have a sensor also connected. I have both of these working independently, so I know it is not a hardware issue, and am trying to display the sensor information on the webserver. The variable I created for the sensor information is not being displayed on the web server. The variable CM reads a number in the serial monitor but reads 0 on my webpage. The t variable being used in the same function to display the webpage works correctly, so I am wondering if I am doing something wrong with the CM variable.
Here is the code:
// Arduino Webserver with Ethernet shield ENC28J60. Static IP or DHCP.
// Webpage shows temperature from sensor DS18B20 and time since reset.
// Library https://github.com/jcw/ethercard ethercard-master rename to ethercardmaster
// 2010-05-28 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
// Library https://github.com/milesburton/Arduino-Temperature-Control-Library rename to DallasTemperature
// Dallas library is buggy. Examples compiled often show -127.
// Code adopted by Janis Alnis 2016.11.30. Compiled with Arduino IDE version 1.0.0.
// ENC SCK -> Arduino pin 13
// ENC SO -> Arduino pin 12
// ENC SI -> Arduino pin 11
// ENC CS -> Arduino pin 10 (some other online examples use pin 8)
// ENC VCC -> 3V3 from USB serial adapter CP2102 or PL2303 but not enough from CH340
// ENC GND -> GND
#include <SPI.h>
#include <EEPROM.h>
#include "RTClib.h"
#include <EtherCard.h>
int trigger = 7;
int echoPin = 8;
RTC_DS1307 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x49,0x2D,0x30,0x33 };
#define STATIC 1 // DHCP=0 , static=1
#if STATIC
static byte myip[] = { 192,168,0,76 }; // static ip address
#endif
byte Ethernet::buffer[500]; BufferFiller bfill;
float t1;
float CM;
int button=3; long state=0; long clicks=0; // for the digital input button
long AIN;
long duration, cm, mm, MM;
void setup(){ Serial.begin(9600);
pinMode(7, OUTPUT);
pinMode(8, INPUT);
#ifndef ESP8266
//while(!Serial);
//wait for serial port to connect
#endif
rtc.begin();
/* If the RTC is uninitialized, set the time to the compile time.
* Set a bit in EEPROM so that we don't set the RTC on reset or reprogram.
* To set the time, clear the bit using eeprom_clear.ino.
if (!rtc.isrunning() || !EEPROM.read(0)) {
Serial.println("Setting RTC");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
EEPROM.write(0, 1);
Serial.println("\nArduino Webserver with ENC28J60 Ethernet");
Serial.println ("Temperature sensor DS18B20 on D8");
pinMode(button, INPUT); digitalWrite(button, HIGH); // button
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
Serial.println( "Failed to access Ethernet controller");
#if STATIC
ether.staticSetup(myip);
#else
if (!ether.dhcpSetup())
Serial.println("DHCP failed");
#endif
ether.printIp("IP: ", ether.myip);
static word homePage() {
long T1=int(t1); long T1A=t1*10-10*T1; // fractional part
long t = millis() / 1000;
bfill = ether.tcpOffset();
bfill.emit_p(PSTR(
"HTTP/1.0 200 OK\r\nContent-Type: text/html\r\nPragma: no-cache\r\n\r\n<meta http-equiv='refresh' content='1'/>"
"<body><html><u>Arduino Ethernet ENC28J60 webserver #3</u><BR><B>Uptime $L (Seconds)<BR><B>Uptime $L (Seconds)"),
t,CM);
return bfill.position();
void loop () {
if (millis()%100>70){if (digitalRead(button)==LOW) {if (state==0) {clicks=clicks+1; state=1;}}
delay(50); if (digitalRead(button)==HIGH){if (state==1) {state=0;}}}
// Serial.print ("t1= "); Serial.println (t1);} // t2 = sensors.getTempCByIndex(1);
AIN=analogRead(A0); AIN=AIN*100/1023; analogWrite(9, AIN);
word len = ether.packetReceive(); word pos = ether.packetLoop(len);
if (pos) ether.httpServerReply(homePage()); // if valid tcp data received send web page
long duration, cm, CM, mm, MM;
DateTime now = rtc.now();
digitalWrite(7, LOW);
delayMicroseconds(2);
digitalWrite(7,HIGH);
delayMicroseconds(10);
digitalWrite(7,LOW);
duration=pulseIn(8, HIGH);
// convert the time into a distance
cm = (duration / 2.0) / 27.9;
mm = (duration / 2.0) / 2.79;
CM = (64.3 - cm); // Substract the total distance in cm by the distance the sensor is measuring
MM = (643 - mm);
delay(10);
/* This poortion of code writes the distance measured by the sensor on one line
* followed by the distance after substraction of total distance
* followed by the date and time the data was calculated
Serial.print(CM);
Serial.print(",cm,");
Serial.print(MM);
Serial.print(",mm,");
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
delay(100);
