so i am trying to send variable data from a cpp file to and ino file and i am getting an error. The purpose of the code is to measure the speed of a moving object. The object will travel 8cm and i am using two ultrasonic distance sensors to determine how long it takes for the object to cover 8cm. So the function MEASURE_BLOCK_DISTANCE will wait for the object to pass it by and will record the time with millis() in T1 and then as the block object continues to move it will pass by a second distance sensor with the function MEASURE_BLOCK_DISTANCE_AGAIN and then it will record the time in T2 once more. Finally the speed will be calculated with SPEED = 8/(T2-T1)
please see below:
Here is my cpp file for MEASURE_BLOCK_DISTANCE which is identical to MEASURE_BLOCK_DISTANCE_AGAIN except that variables have a 2 at the end
#include <MEASURE_BLOCK_DISTANCE_AGAIN.h>
void MEASURE_BLOCK_DISTANCE_AGAIN(float* T2) {
const int trigPin2 = 10;
const int echoPin2 = 11;
long duration;
int distance;
//float T2;
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
int i = 1;
while(i){
digitalWrite(trigPin2, LOW); // make sure trig pin is initialy low
delayMicroseconds(2);
digitalWrite(trigPin2, HIGH);
delayMicroseconds(11);
duration = pulseIn(echoPin2, HIGH); // output proportional to range
distance = duration*0.034/2; //0.034cm/microsec
Serial.print("Distance: ");
Serial.println(distance);
if (distance < 10){
T2 = millis(); // T2 to be defined in final software
delay(10);
//Serial.println(T2);
//Serial.println(5/T1,5);
delay(10);
i =0;
return(T2);
Here is my code for the MEASURE_BLOCK_DISTANCE header file which is identical to MEASURE_BLOCK_DISTANCE_AGAIN except every variable has a 2 at the end
// Define guards for this header
#ifndef MEASURE_BLOCK_DISTANCE_H
#define MEASURE_BLOCK_DISTANCE_H
extern float T1;
// Define guards to make sure .c functions/objects play nicely with .cpp functions/objects
// #ifdef __cplusplus
// extern "C" {
// #endif
* Function Prototypes
void MEASURE_BLOCK_DISTANCE(float* T1);
// #endif // __cplusplus
#endif // MEASURE_BLOCK_DISTANCE_H
Here is the source code, the ino file that i want to send T2 and T1 to.
#include <MEASURE_BLOCK_DISTANCE.h>
MEASURE_BLOCK_DISTANCE(&T1);
MEASURE_BLOCK_DISTANCE_AGAIN(&T2);
float SPEED = 8/(&T2-&T1);
Serial.println(SPEED);
Finally here is the error message that i am receiving:
C:\Users\frank\AppData\Local\Temp\ccea9PKf.ltrans0.ltrans.o: In function `setup':
C:\Users\frank\Desktop\SORTING_ROBOT_SW\SIT_IntegrationTestofSomeComponents/SIT_IntegrationTestofSomeComponents.ino:46: undefined reference to `T2'
C:\Users\frank\Desktop\SORTING_ROBOT_SW\SIT_IntegrationTestofSomeComponents/SIT_IntegrationTestofSomeComponents.ino:46: undefined reference to `T1'
collect2.exe: error: ld returned 1 exit status
Any help will be greatly appreciated.
