Passive Infrared Sensor
I found this product at the link below and am confused as to what it outputs. I am familiar with a standard PIR motion sensors. I was wondering if this sensor could be used for a temperature sensor. http://www.goldmine-elec-products.com/prodinfo.asp?number=G18937
An infrared sensor is always some kind of temperature sensor but if you wanna have a sensor to get some degree Celsius or Fahrenheit this is not the kind of sensor you should buy.
This http://shop.boxtec.ch/infrared-thermometer-sensor-mlx90614esf-p-40686.html is an infrared temperature sensor.
PIR sensors are normally used on a pcb along with a wide-field fresnel lenses,
and respond to “moving” heat sources, like a walking human. There is
probably something similar to a G18937 insude this:
http://learn.parallax.com/KickStart/555-28027
