My project is smart locker system.The components used are RFID reader, Keypad,LCD with I2C, Arduino Mega and relay.
What my project should do is ,initially we provide RFID tag to the system.If the rfid tag is currect the system will ask for password.If the password is matched the locker will OPEN.If someone tries to break the locker the vibration sensor fixed on the locker should find the anomally and trigger the siren which is a buzzer in this case.If a predefined security code is entered the siren should stop.
But the problem here i am having is everything works fine except last part.When the vibration sensor detects the vibration buzzer gets activated but while entering the security code the siren is not stopping.I done many troubleshooting methods including debugging using serial monitor.But the problem is not solving.All modules are working properly.
I think the problem is in the cod, and i have limited knowledge in programming .I would be graceful if someone intent to help me.
// Include required libraries
#include <MFRC522.h>
#include <Keypad.h>
#include <SPI.h>
// Create instances
LiquidCrystal_I2C lcd(0x27, 16, 2);
MFRC522 mfrc522(53, 2); // MFRC522 mfrc522(SS_PIN, RST_PIN)
// Initialize Pins for led's, servo and buzzer
// Blue LED is connected to 5V
constexpr uint8_t greenLed = 33;
constexpr uint8_t redLed = 35;
constexpr uint8_t relay = 13;
constexpr uint8_t buzzerPin = 12;
constexpr uint8_t vib_pin = 10;
char initial_password[4] = {'1', '2', '3', '4'}; // Variable to store initial password
String tagUID = "C9 60 21 B3"; // String to store UID of tag. Change it with your tag's UID
char password[4]; // Variable to store users password
boolean RFIDMode = true; // boolean to change modes
char key_pressed = 0; // Variable to store incoming keys
uint8_t i = 0; // Variable used for counter
// defining how many rows and columns our keypad have
const byte rows = 4;
const byte columns = 4;
// Keypad pin map
char hexaKeys[rows][columns] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
// Initializing pins for keypad
byte row_pins[rows] = {9, 8, 7, 6};
byte column_pins[columns] = {5, 4, 3};
// Create instance for keypad
Keypad keypad_key = Keypad( makeKeymap(hexaKeys), row_pins, column_pins, rows, columns);
boolean alarmIsActive = false;
// Arduino Pin configuration
pinMode(buzzerPin, OUTPUT);
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(relay, OUTPUT);
pinMode(vib_pin, INPUT);
lcd.init(); // LCD screen
lcd.backlight();
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
lcd.clear(); // Clear LCD screen
security();
// System will first look for mode
if (RFIDMode == true) {
lcd.setCursor(0, 0);
lcd.print(" Persnl locker ");
lcd.setCursor(0, 1);
lcd.print(" Scan Your Tag ");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
//Reading from the card
String tag = "";
for (byte j = 0; j < mfrc522.uid.size; j++)
tag.concat(String(mfrc522.uid.uidByte[j] < 0x10 ? " 0" : " "));
tag.concat(String(mfrc522.uid.uidByte[j], HEX));
tag.toUpperCase();
//Checking the card
if (tag.substring(1) == tagUID)
// If UID of tag is matched.
lcd.clear();
lcd.print("Tag Matched");
digitalWrite(greenLed, HIGH);
delay(3000);
digitalWrite(greenLed, LOW);
lcd.clear();
lcd.print("Enter Password:");
RFIDMode = false; // Make RFID mode false
// If UID of tag is not matched.
lcd.clear();
lcd.print("Wrong Tag Shown");
lcd.print("Access Denied");
digitalWrite(buzzerPin, HIGH);
digitalWrite(redLed, HIGH);
delay(3000);
digitalWrite(buzzerPin, LOW);
digitalWrite(redLed, LOW);
lcd.clear();
// If RFID mode is false, it will look for keys from keypad
if (RFIDMode == false) {
key_pressed = keypad_key.getKey(); // Storing keys
if (key_pressed)
password[i++] = key_pressed; // Storing in password variable
lcd.print("*");
if (i == 4) // If 4 keys are completed
delay(200);
if (!(strncmp(password, initial_password, 4))) // If password is matched
lcd.clear();
lcd.print("Pass Accepted");
digitalWrite(relay, HIGH);
delay(5000);
digitalWrite(relay, LOW);
lcd.clear();
i = 0;
RFIDMode = true; // Make RFID mode true
else // If password is not matched
lcd.clear();
lcd.print("Wrong Password");
delay(3000);
lcd.clear();
i = 0;
void security()
int val = 0;
val = digitalRead(vib_pin); //read vib pin
if (val == 1)
vib_sensor();
alarmIsActive = true; //global boolean assighned made true if vib pin detect input
if (alarmIsActive = true) // only run if vib pin detect input
keypass();
warning();
void vib_sensor() //alarm triggering function
digitalWrite(buzzerPin, HIGH); // make vib pin high
lcd.clear();
lcd.print("U R undr theft");
void warning() //warning message function
lcd.clear();
lcd.print("WARNING");
void keypass() //password for vibration sensor after triggered function
char alarm_password[3] = {'8', '8', '8'}; // Variable to store initial password
char pass[3]; // Variable to store alarm password
char key_pressed_alarm = 0;
uint8_t j = 0; // Variable used for counter
key_pressed_alarm = keypad_key.getKey(); // Storing keys that we input
if (key_pressed_alarm)
pass[j++] = key_pressed_alarm ; // Storing in password variable
lcd.print("*");
if (j == 3) // If 3 keys entered are completed
delay(200);
if (!(strncmp(pass, alarm_password, 3))) // If password is matched
lcd.clear();
j = 0;
