Password with touchsheild
So ive been studying the code for the arduino touch shield located here. I think I have a pretty good understanding of the code so far Im just not sure how I would set up a password to power a pin on the arduino. This is what im working on now can any one give points for my code?
 Touch Sense Shield Example using the MPR121 touch sensor IC
 SparkFun Electronics
 created on: February 25, 2013
 license: Beerware. Feel free to use, reuse, modify and do
 anything with this code. If you find it useful, you can buy me a
 beer next time we meet!
 This is a simple example sketch to show of the functionality of
 the MPR121 capacitive touch sensor. Pressing a pad will print the
 corresponding number onto the Serial Monitor at 9600 bps.
 Hardware: Any Arduino.
// include the atmel I2C libs
#include "mpr121.h"
#include <Wire.h>
const byte MPR121_ADDRESS = 0x5A;
// Match key inputs with electrode numbers
// The defined numbers match up to key labels on the touch shield
#define ELE1 8
#define ELE2 5
#define ELE3 2
#define ELE4 7
#define ELE5 4
#define ELE6 1
#define ELE7 6
#define ELE8 3
#define ELE9 0
//extras (not connected to buttons on the shield)
#define ELE9 9
#define ELE10 10
#define ELE11 11
//interupt pin
const byte irqPin = 2;  // D2
  //make sure the interrupt pin is an input and pulled high
  pinMode(irqPin, INPUT);
  digitalWrite(irqPin, HIGH);
  Serial.begin(9600); //configure serial out
  Wire.begin(); // initalize I2C bus
  mpr121QuickConfig(); // initialize mpr121
  Serial.println("MPR121 Initialized. Press buttons!");
  if (!digitalRead(irqPin))
    getNumber();
void getNumber()
  int touchNumber = 0;
  uint16_t touchstatus;
  char digits;
  touchstatus = getTouchStatus();
  for (int j=0; j<12; j++)  // Check how many electrodes were pressed
    if ((touchstatus & (1<<j)))
      touchNumber++;
  if (touchNumber == 1)
    if (touchstatus & (1<<ELE7))
      digits = '7';
    else if (touchstatus & (1<<ELE4))
      digits = '4';
    else if (touchstatus & (1<<ELE1))
      digits = '1';
    else if (touchstatus & (1<<ELE8))
      digits = '8';
    else if (touchstatus & (1<<ELE5))
      digits = '5';
    else if (touchstatus & (1<<ELE2))
      digits = '2';
    else if (touchstatus & (1<<ELE9))
      digits = '9';
    else if (touchstatus & (1<<ELE6))
      digits = '6';
    else if (touchstatus & (1<<ELE3))
      digits = '3';
    Serial.println(digits);
  //do nothing if more than one button is pressed, or if all are released
  else if (touchNumber == 0)
/* getTouchStatus() will return a 16-bit value that relates the
current touched status of each button. The LSB represents electrodes
0-7 (bit 0 = electrode 0), and the lowest 4 bits of the MSB
represent electrods 8-11. A 1 means a button is being touched.*/
unsigned int getTouchStatus()
  Wire.beginTransmission(MPR121_ADDRESS); // Transmit I2C address
  Wire.write(0x00);  // Write register address of touch status byte
  Wire.endTransmission(false);  // Transmit bytes, and send restart message
  Wire.requestFrom(MPR121_ADDRESS, (byte) 2);
  byte lsb = Wire.read();
  byte msb = Wire.read();
  unsigned int touch = ((msb << 8) | lsb);
  return touch;
/* mpr121Read(byte) will read a byte from the register at location
address. */
byte mpr121Read(byte address)
  Wire.write(address);  // Write register address
  Wire.requestFrom(MPR121_ADDRESS, (byte) 1);
  byte value = Wire.read();
  return value;
/* mpr121Write(byte, byte) will write a byte (data) to a register
(at address). */
void mpr121Write(byte address, byte data)
  Wire.write(data);
  Wire.endTransmission();
void mpr121QuickConfig(void)
  // Section A
  // This group controls filtering when data is > baseline.
  mpr121Write(MHD_R, 0x01);
  mpr121Write(NHD_R, 0x01);
  mpr121Write(NCL_R, 0x00);
  mpr121Write(FDL_R, 0x00);
  // Section B
  // This group controls filtering when data is < baseline.
  mpr121Write(MHD_F, 0x01);
  mpr121Write(NHD_F, 0x01);
  mpr121Write(NCL_F, 0xFF);
  mpr121Write(FDL_F, 0x02);
  // Section C
  // This group sets touch and release thresholds for each electrode
  mpr121Write(ELE0_T, TOU_THRESH);
  mpr121Write(ELE0_R, REL_THRESH);
  mpr121Write(ELE1_T, TOU_THRESH);
  mpr121Write(ELE1_R, REL_THRESH);
  mpr121Write(ELE2_T, TOU_THRESH);
  mpr121Write(ELE2_R, REL_THRESH);
  mpr121Write(ELE3_T, TOU_THRESH);
  mpr121Write(ELE3_R, REL_THRESH);
  mpr121Write(ELE4_T, TOU_THRESH);
  mpr121Write(ELE4_R, REL_THRESH);
  mpr121Write(ELE5_T, TOU_THRESH);
  mpr121Write(ELE5_R, REL_THRESH);
  mpr121Write(ELE6_T, TOU_THRESH);
  mpr121Write(ELE6_R, REL_THRESH);
  mpr121Write(ELE7_T, TOU_THRESH);
  mpr121Write(ELE7_R, REL_THRESH);
  mpr121Write(ELE8_T, TOU_THRESH);
  mpr121Write(ELE8_R, REL_THRESH);
  mpr121Write(ELE9_T, TOU_THRESH);
  mpr121Write(ELE9_R, REL_THRESH);
  mpr121Write(ELE10_T, TOU_THRESH);
  mpr121Write(ELE10_R, REL_THRESH);
  mpr121Write(ELE11_T, TOU_THRESH);
  mpr121Write(ELE11_R, REL_THRESH);
  // Section D
  // Set the Filter Configuration
  // Set ESI2
  mpr121Write(FIL_CFG, 0x04);
  // Section E
  // Electrode Configuration
  // Enable 6 Electrodes and set to run mode
  // Set ELE_CFG to 0x00 to return to standby mode
  mpr121Write(ELE_CFG, 0x0C);	// Enables all 12 Electrodes
  //mpr121Write(ELE_CFG, 0x06);		// Enable first 6 electrodes
  // Section F
  // Enable Auto Config and auto Reconfig
  /*mpr121Write(ATO_CFG0, 0x0B);
  mpr121Write(ATO_CFGU, 0xC9);	// USL = (Vdd-0.7)/vdd*256 = 0xC9 @3.3V   mpr121Write(ATO_CFGL, 0x82);	// LSL = 0.65*USL = 0x82 @3.3V
  mpr121Write(ATO_CFGT, 0xB5);*/	// Target = 0.9*USL = 0xB5 @3.3V
so if i wanted to make i so if i hit 1 it would turn power to pin 1 would it be somthing like this? Im not sure how to define multiple touchstatus like 777 digital write (1, HIGH)
   digitalWrite (1, HIGH)
What does getNumber() accomplish? It doesn't return a value, and I don't see it setting a global to any number that represents anything useful.
Can you point me in the right direction maby? link to a reference that my help?
